I have the following ethernet controller in my laptop
08:00.0 Ethernet controller: Qualcomm Atheros Killer E2500 Gigabit Ethernet Controller (rev 10)
and I keep getting these warnings in my journalctl -xe output
Nov 30 05:22:55 laptonix kernel: alx 0000:08:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
Nov 30 05:22:55 laptonix kernel: alx 0000:08:00.0:   device [1969:e0b1] error status/mask=00000080/00002000
Nov 30 05:22:55 laptonix kernel: alx 0000:08:00.0:    [ 7] BadDLLP
Nov 30 05:22:56 laptonix kernel: pcieport 0000:00:1d.4: AER: Corrected error received: 0000:08:00.0
Nov 30 05:22:56 laptonix kernel: alx 0000:08:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
Nov 30 05:22:56 laptonix kernel: alx 0000:08:00.0:   device [1969:e0b1] error status/mask=00000040/00002000
Nov 30 05:22:56 laptonix kernel: alx 0000:08:00.0:    [ 6] BadTLP
the above messages keep spamming with occasional error messages like
Nov 30 05:23:15 laptonix kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=143095 end=143096) time 1792 us, min 1062, max 1079, scanline start 962, end 60
I am using Kubuntu 21.10 with kernel version 5.13.0-21-generic also tested with 21.04 on live usb and had the same messages.
I have read many solutions revolving around adding to kernel boot pci=nomsi or pci=noaer or pcie_aspm=off but none of these worked for me.
Is this a bug in the kernel or is there something I can do to stop these messages from appearing in the logs?
The output of sudo dmidecode -s bios-version is V1.12 which is the latest available and the laptop is Acer Predator Helios 300 PH315-52
EDIT:
the output of lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers [8086:3ec4] (rev 07)
00:01.0 PCI bridge [0604]: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07)
00:02.0 VGA compatible controller [0300]: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630] [8086:3e9b]
00:04.0 Signal processing controller [1180]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem [8086:1903] (rev 07)
00:08.0 System peripheral [0880]: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model [8086:1911]
00:12.0 Signal processing controller [1180]: Intel Corporation Cannon Lake PCH Thermal Controller [8086:a379] (rev 10)
00:14.0 USB controller [0c03]: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller [8086:a36d] (rev 10)
00:14.2 RAM memory [0500]: Intel Corporation Cannon Lake PCH Shared SRAM [8086:a36f] (rev 10)
00:14.3 Network controller [0280]: Intel Corporation Cannon Lake PCH CNVi WiFi [8086:a370] (rev 10)
00:15.0 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 [8086:a368] (rev 10)
00:15.1 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #1 [8086:a369] (rev 10)
00:16.0 Communication controller [0780]: Intel Corporation Cannon Lake PCH HECI Controller [8086:a360] (rev 10)
00:17.0 SATA controller [0106]: Intel Corporation Cannon Lake Mobile PCH SATA AHCI Controller [8086:a353] (rev 10)
00:1b.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 [8086:a32c] (rev f0)
00:1d.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 [8086:a330] (rev f0)
00:1d.4 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port #13 [8086:a334] (rev f0)
00:1f.0 ISA bridge [0601]: Intel Corporation HM470 Chipset LPC/eSPI Controller [8086:a30d] (rev 10)
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
00:1f.4 SMBus [0c05]: Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] (rev 10)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller [8086:a324] (rev 10)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] [10de:2191] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation TU116 High Definition Audio Controller [10de:1aeb] (rev a1)
01:00.2 USB controller [0c03]: NVIDIA Corporation TU116 USB 3.1 Host Controller [10de:1aec] (rev a1)
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU116 USB Type-C UCSI Controller [10de:1aed] (rev a1)
06:00.0 Non-Volatile memory controller [0108]: Kingston Technology Company, Inc. U-SNS8154P3 NVMe SSD [2646:5008] (rev 01)
07:00.0 Non-Volatile memory controller [0108]: Phison Electronics Corporation E16 PCIe4 NVMe Controller [1987:5016] (rev 01)
08:00.0 Ethernet controller [0200]: Qualcomm Atheros Killer E2500 Gigabit Ethernet Controller [1969:e0b1] (rev 10)
the output of lspci -tv
-[0000:00]-+-00.0  Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers
           +-01.0-[01-05]--+-00.0  NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile]
           |               +-00.1  NVIDIA Corporation TU116 High Definition Audio Controller
           |               +-00.2  NVIDIA Corporation TU116 USB 3.1 Host Controller
           |               \-00.3  NVIDIA Corporation TU116 USB Type-C UCSI Controller
           +-02.0  Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
           +-04.0  Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
           +-08.0  Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
           +-12.0  Intel Corporation Cannon Lake PCH Thermal Controller
           +-14.0  Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller
           +-14.2  Intel Corporation Cannon Lake PCH Shared SRAM
           +-14.3  Intel Corporation Cannon Lake PCH CNVi WiFi
           +-15.0  Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0
           +-15.1  Intel Corporation Cannon Lake PCH Serial IO I2C Controller #1
           +-16.0  Intel Corporation Cannon Lake PCH HECI Controller
           +-17.0  Intel Corporation Cannon Lake Mobile PCH SATA AHCI Controller
           +-1b.0-[06]----00.0  Kingston Technology Company, Inc. U-SNS8154P3 NVMe SSD
           +-1d.0-[07]----00.0  Phison Electronics Corporation E16 PCIe4 NVMe Controller
           +-1d.4-[08]----00.0  Qualcomm Atheros Killer E2500 Gigabit Ethernet Controller
           +-1f.0  Intel Corporation HM470 Chipset LPC/eSPI Controller
           +-1f.3  Intel Corporation Cannon Lake PCH cAVS
           +-1f.4  Intel Corporation Cannon Lake PCH SMBus Controller
           \-1f.5  Intel Corporation Cannon Lake PCH SPI Controller
the output of sudo lshw -C network
  *-network
       description: Wireless interface
       product: Cannon Lake PCH CNVi WiFi
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       logical name: wlp0s20f3
       version: 10
       serial: a8:6d:aa:e7:91:f4
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.13.0-21-generic firmware=46.6b541b68.0 9000-pu-b0-jf-b0- ip=192.168.1.102 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:16 memory:b4618000-b461bfff
  *-network
       description: Ethernet interface
       product: Killer E2500 Gigabit Ethernet Controller
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:08:00.0
       logical name: enp8s0
       version: 10
       serial: 7c:d3:0a:80:eb:d6
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=alx driverversion=5.13.0-21-generic latency=0 link=no multicast=yes port=twisted pair
       resources: irq:16 memory:b4300000-b433ffff ioport:3000(size=128)
Farahats9
  • 111
sudo -H gedit /etc/default/grub # edit this file
Find:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Change it to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=noaer"
Save the file.
sudo update-grub # update GRUB
reboot # reboot the computer
heynnema
  • 73,649
