I'm compiling Qemu with --enable-gtk enabled. .configure gives me the following error messages:
Run-time dependency gtk+-3.0 found: NO
../meson.build:1042:2: ERROR: Could not generate cargs for gtk+-3.0: Package pango was not found in the pkg-config search path. Perhaps you should add the directory containing `pango.pc' to the PKG_CONFIG_PATH environment variable Package 'pango', required by 'gdk-3.0'(is this a typo?), not found
A full log can be found at .../qemu-6.2.0-rc2/build/meson-logs/meson-log.txt
ERROR: meson setup failed
I searched in Ubuntu package search webpage for 'pango', but it gives me so many results that I don't know which one is the correct 'pango' I should install to pass the gtk-3 configure. So, what is the package name for 'pango' that gtk+-3.0 needs?
PS, I'm on Ubuntu 20.04 and the Qemu I'm trying to build is 6.2.
zzzhhh
  • 307
There are many tools involved into building process. One of them is pkg-config. It searches for files with .pc extension. For Gtk3 and Pango you need to install the following packages:
sudo apt-get install libgtk-3-dev libpango1.0-dev
But finding and installing every single package may be time consuming procedure. So you have two options here:
  • install build-dependencies for existing QEMU by
    sudo apt-get update
    sudo apt-get upgrade
    sudo apt-get build-dep qemu
    and then compile newer QEMU on your own.
  • install newer binary QEMU 6.0 from PPA using commands below:
    sudo add-apt-repository ppa:flexiondotorg/quickemu
    sudo apt-get update
    sudo apt-get install qemu
N0rbert
  • 103,263
