I have to add to a trust list my self signed certificate ,but now I need to remove it
I am looking for the proper way to do so, without braking the system
This is the way I added:
I copied the certificate at this location:
/usr/local/share/ca-certificates
the I run the command:
update-ca-certificates
Now I need to remove it, because I need to create a wild card certificate and again add it to a trust list
I can see the certificate in:
/etc/ssl/certs
and I've been thinking to just remove it from both locations and run again
but I am not sure, if this will work
Thank you
xlameee
If you want to remove your certificate, here is the steps that you should follow:
  1. remove your certificate file from /usr/local/share/ca-certificates
  2. run update-ca-certificates -f
According to the man pages for update-ca-certificates, add the -f switch do the job for you:
-f, --fresh
          Fresh updates.  Remove symlinks in /etc/ssl/certs directory.
This will recreate a new ca-certificate.crt file without your custom root CA certificate and remove the symlink associated with it from /etc/ssl/certs/.
MHM
  • 111
-1
I manually edited the file /etc/ssl/certs/ca-certificates.crt
But I'm not confident this is the correct approach, however removing the file /usr/local/share/ca-certificates did not remove the cert from /etc/ssl/certs/ca-certificates.crt
