23
I remember the nice mv somefile ~/.Trash command but that folder does not exist on newer Ubuntus. Does anyone know why?
Braiam
  • 69,112
According to the freedesktop.org Trash Specification:
For every user a “home trash” directory MUST be available. Its name and location are $XDG_DATA_HOME/Trash ; $XDG_DATA_HOME is the base directory for user-specific data, as defined in the Desktop Base Directory Specification.
If the environment variable $XDG_DATA_HOME is either not set or empty, ~/.local/share is used. So by default, the trash folder is ~/.local/share/Trash.
Regardless, the easiest and best way to trash a file from the command line is to use the trashInstall trash-cli command.
Use it like you would use rm:
trash somefile.txt
This is better than just mv'ing a file into ~/.local/share/Trash because it stores metadata such as where the file was originally so you can restore (un-delete) it if need be.
Gary Wang
  • 173
Isaiah
  • 60,750
10
You can find it here. ~/.local/share/Trash/
aneeshep
  • 30,949
it is because of the latest XDG Base Directory Specification: http://standards.freedesktop.org/basedir-spec/basedir-spec-latest.html
Praweł
  • 6,536
