How can I permanently change PATH variable in Ubuntu 20.04?
What file should I modify?
Thank You
Thank You
You can just add it to your ~/.profile or ~/.bashrc or ~/.THESHELLYOUHAVErc
like adding :
export PATH=$PATH:/some-new/:./another
changing might be more like
export PATH=yourneed1/:yourneed2/
without the existing one $PATH
but you need to adapt that to your own needs
you have to logout or reload the file source ~/.profile once, it is not instantly done ;) (similar with .bashrc)
