-4
I upgraded Ubuntu 18.04 to 20.04 and now everything is broken. apt doesn't work.keep getting dpkg errors when trying to use it. cant install anything. nautilus and terminal doesn't work. lots of icons are not appearing.broken icons broken icons2 broken icons3
some python errors occurring and so on. what to do now? even backup program doesn't work. How to make it work again? I couldn't understand how canonical cant send a proper upgrade
EDIT1: are there any way to remove and reinstall all needed packages? apt actually works but giving different errors.
EDIT2:for making an example, after running sudo apt install terminator Quarter of output is:
dpkg: dependency problems prevent configuration of terminator:
 terminator depends on python3-configobj; however:
  Package python3-configobj is not configured yet.
 terminator depends on python3-gi; however:
  Package python3-gi is not configured yet.
 terminator depends on python3-gi-cairo; however:
  Package python3-gi-cairo is not configured yet.
 terminator depends on python3-psutil; however:
  Package python3-psutil is not configured yet.
 terminator depends on python3:any; however:
  Package python3 is not configured yet.
dpkg: error processing package terminator (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of python3-nacl: python3-nacl depends on python3 (>= 3~); however: Package python3 is not configured yet. python3-nacl depends on python3-six; however: Package python3-six is not configured yet. python3-nacl depends on python3:any; however: Package python3 is not configured yet.
dpkg: error processing package python3-nacl (--configure): dependency problems - leaving unconfigured Setting up libgtk-3-common (3.24.20-0ubuntu1) ... dpkg: dependency problems prevent configuration of python3-systemd: python3-systemd depends on python3 (<< 3.9); however: Package python3 is not configured yet. python3-systemd depends on python3 (>= 3.8~); however: Package python3 is not configured yet. python3-systemd depends on python3:any; however: Package python3 is not configured yet.
dpkg: error processing package python3-systemd (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of python3-cffi-backend: python3-cffi-backend depends on python3 (<< 3.9); however: Package python3 is not configured yet. python3-cffi-backend depends on python3 (>= 3.8~); however: Package python3 is not configured yet.
dpkg: error processing package python3-cffi-backend (--configure): dependency problems - leaving unconfigured dpkg: too many errors, stopping Processing triggers for libc-bin (2.31-0ubuntu9.2) ... Processing triggers for dictionaries-common (1.28.1) ... Errors were encountered while processing: python3 python3-psutil apport python3-tz python3-apport python3-cupshelpers python3-monotonic python3-requests-unixsocket python3-six python3-simplejson python3-cups python3-oauthlib python3-chardet python3-configobj python3-secretstorage system-config-printer python3-certifi python3-pexpect python3-cryptography python3-wadllib python3-gi python3-requests python3-ldb python3-idna python3-fasteners python3-urllib3 gnome-shell ubuntu-session ibus gdm3 python3-defer duplicity python3-keyring python3-httplib2 language-selector-common python3-paramiko lsb-release python3-protobuf python3-future python3-rfc3339 python3-macaroonbakery python3-aptdaemon.gtk3widgets python3-ibus-1.0 python3-lazr.restfulclient python3-gi-cairo python3-lib2to3 terminator python3-nacl python3-systemd python3-cffi-backend Processing was halted because there were too many errors.
EDIT3: output of sudo apt-get install aptitude : https://pastecode.io/s/9eo7pji8
output of sudo aptitude dist-upgrade : https://pastecode.io/s/dgnjw0z9
output of apt-cache policy : https://pastecode.io/s/w5rso9um
EDIT4: i tried sudo dpkg --configure -a sudo apt-get install -f and got same errors as apt-get install terminator gives. Just last two rows are:
EDIT5:Suddenly my gnome-terminal started to work. But nautilis still doesnt work. And after running recommended commands:
export PATH="/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"
cd ~/Downloads apt-get download python3-minimal dpkg -l | grep ^ii | grep python sudo -E dpkg -i --force-all ./python3-minimal*.deb
sudo -E dpkg --configure -a sudo -E apt-get install -f sudo -E apt-get install --reinstall python3-minimal sudo -E apt-get install --reinstall $(dpkg -l | grep ^ii | grep python | awk '{print $2}') sudo -E dpkg --configure -a sudo -E apt-get install -f
sudo -E apt-get install aptitude sudo -E aptitude safe-upgrade sudo -E aptitude dist-upgrade
the output is: https://pastecode.io/s/ytobvrny still getting same errors as above.
EDIT6: I just tried something before your posts and removed nvidia driver. After that my gui gone. Then i removed windows(it was dual boot system) and my ttys gone too. I didnt remember my password so couldnt log in for a couple days. Now i cant enter grub for maybe trying recovery mode.
I just use live usb and restored chrome on live usb. Now what can i do? Is it possible to do something from live usb to restore my installed os again? i tried @N0rbert's answer partially before my gui gone but i got similar errors again. But didnt complete to install all downloaded debs.
hepl
  • 37
please try N0berts answer first
I would recommend reinstalling possibly problematic packages at a low level:
cd ~/Downloads apt-get download python3-minimal sudo -E dpkg -i --force-all ./python3-minimal*.deb
Try to fix each package separately:
mkdir ~/Downloads/debs
cd ~/Downloads/debs
apt-get download devhelp dput gdebi-core python3 python3-psutil apport python3-tz python3-apport python3-cupshelpers python3-monotonic python3-requests-unixsocket python3-six python3-simplejson python3-cups python3-oauthlib python3-chardet python3-configobj python3-secretstorage system-config-printer python3-certifi python3-pexpect python3-cryptography python3-wadllib python3-gi python3-requests python3-ldb python3-idna python3-fasteners python3-urllib3 gnome-shell ubuntu-session ibus gdm3 python3-defer duplicity python3-keyring python3-httplib2 language-selector-common python3-paramiko lsb-release python3-protobuf python3-future python3-rfc3339 python3-macaroonbakery python3-aptdaemon.gtk3widgets python3-ibus-1.0 python3-lazr.restfulclient python3-gi-cairo python3-lib2to3 terminator python3-nacl python3-systemd python3-cffi-backend
sudo dpkg -i --force-all ./devhelp.deb sudo dpkg -i --force-all ./dput.deb sudo dpkg -i --force-all ./gdebi-core.deb sudo dpkg -i --force-all ./python3.deb sudo dpkg -i --force-all ./python3-psutil.deb sudo dpkg -i --force-all ./apport.deb sudo dpkg -i --force-all ./python3-tz.deb sudo dpkg -i --force-all ./python3-apport.deb sudo dpkg -i --force-all ./python3-cupshelpers.deb sudo dpkg -i --force-all ./python3-monotonic.deb sudo dpkg -i --force-all ./python3-requests-unixsocket.deb sudo dpkg -i --force-all ./python3-six.deb sudo dpkg -i --force-all ./python3-simplejson.deb sudo dpkg -i --force-all ./python3-cups.deb sudo dpkg -i --force-all ./python3-oauthlib.deb sudo dpkg -i --force-all ./python3-chardet.deb sudo dpkg -i --force-all ./python3-configobj.deb sudo dpkg -i --force-all ./python3-secretstorage.deb sudo dpkg -i --force-all ./system-config-printer.deb sudo dpkg -i --force-all ./python3-certifi.deb sudo dpkg -i --force-all ./python3-pexpect.deb sudo dpkg -i --force-all ./python3-cryptography.deb sudo dpkg -i --force-all ./python3-wadllib.deb sudo dpkg -i --force-all ./python3-gi.deb sudo dpkg -i --force-all ./python3-requests.deb sudo dpkg -i --force-all ./python3-ldb.deb sudo dpkg -i --force-all ./python3-idna.deb sudo dpkg -i --force-all ./python3-fasteners.deb sudo dpkg -i --force-all ./python3-urllib3.deb sudo dpkg -i --force-all ./gnome-shell.deb sudo dpkg -i --force-all ./ubuntu-session.deb sudo dpkg -i --force-all ./ibus.deb sudo dpkg -i --force-all ./gdm3.deb sudo dpkg -i --force-all ./python3-defer.deb sudo dpkg -i --force-all ./duplicity.deb sudo dpkg -i --force-all ./python3-keyring.deb sudo dpkg -i --force-all ./python3-httplib2.deb sudo dpkg -i --force-all ./language-selector-common.deb sudo dpkg -i --force-all ./python3-paramiko.deb sudo dpkg -i --force-all ./lsb-release.deb sudo dpkg -i --force-all ./python3-protobuf.deb sudo dpkg -i --force-all ./python3-future.deb sudo dpkg -i --force-all ./python3-rfc3339.deb sudo dpkg -i --force-all ./python3-macaroonbakery.deb sudo dpkg -i --force-all ./python3-aptdaemon.gtk3widgets.deb sudo dpkg -i --force-all ./python3-ibus-1.0.deb sudo dpkg -i --force-all ./python3-lazr.restfulclient.deb sudo dpkg -i --force-all ./python3-gi-cairo.deb sudo dpkg -i --force-all ./python3-lib2to3.deb sudo dpkg -i --force-all ./terminator.deb sudo dpkg -i --force-all ./python3-nacl.deb sudo dpkg -i --force-all ./python3-systemd.deb sudo dpkg -i --force-all ./python3-cffi-backend
sudo apt-get install --reinstall devhelp dput gdebi-core python3 python3-psutil apport python3-tz python3-apport python3-cupshelpers python3-monotonic python3-requests-unixsocket python3-six python3-simplejson python3-cups python3-oauthlib python3-chardet python3-configobj python3-secretstorage system-config-printer python3-certifi python3-pexpect python3-cryptography python3-wadllib python3-gi python3-requests python3-ldb python3-idna python3-fasteners python3-urllib3 gnome-shell ubuntu-session ibus gdm3 python3-defer duplicity python3-keyring python3-httplib2 language-selector-common python3-paramiko lsb-release python3-protobuf python3-future python3-rfc3339 python3-macaroonbakery python3-aptdaemon.gtk3widgets python3-ibus-1.0 python3-lazr.restfulclient python3-gi-cairo python3-lib2to3 terminator python3-nacl python3-systemd python3-cffi-backend
and then repeat the above commands from a smaller code block.
If N0berts answer didn't work then I am sorry, You need to go on to dangerous commands or complete reinstall
Before running the below commands please do the following(it is optional but let us not take a risk) -
  • install the ubuntu iso file
  • verify it (optional)
  • burn the iso to a cd-dvd-usb etc.
  • backup /home
  • done
Please don't break your system by doing something you shouldn't have done, If you don't understand anything please ask, I am pretty sure that most of the commands will just go above your head, So feel free to ask anything.
First of all start by running
sudo apt --fix-broken install
After running the above command try installing aptitude once again by
sudo apt -f install aptitude
Let's see if this works or not
If this didn't work then try running this
sudo rm -rf /var/cache/apt/archives/*.deb
After this try installing aptitude once again
If the error is still there then there is no luck for friendly solutions, but you need to forcefully remove all the problem packages
How to do that
See the error message
 python3
 python3-psutil
 apport
 python3-tz
 python3-apport
 python3-cupshelpers
 python3-monotonic
 python3-six
 python3-simplejson
 python3-cups
 python3-oauthlib
 python3-chardet
 python3-configobj
 python3-certifi
 python3-pexpect
 python3-wadllib
 python3-gi
 python3-requests
 python3-ldb
 python3-idna
 python3-fasteners
 python3-urllib3
 gnome-shell
 ubuntu-session
 ibus
 gdm3
 python3-defer
 duplicity
 python3-keyring
 python3-httplib2
 python3-paramiko
 lsb-release
 python3-protobuf
 python3-future
 python3-rfc3339
 python3-ibus-1.0
 python3-gi-cairo
 python3-lib2to3
 terminator
 python3-nacl
 python3-systemd
So to fix you need to manually remove them from doing database
how
Do this all in grub recovery mode by pressing the shift key before the boot logo appears and the advanced option for ubuntu > Recovery mode > Drop to a root shell // OR Open a TTY first to run the below commands by pressing ctrl + alt + f5, log in there with your (sudo)username and password
Go to /var/lib/dpkg/info
cd /var/lib/dpkg/info/
Now as we saw the error above we need to delete problem packages
See this line
errors were encountered during processing
It means after this line everything that came is just a package name
So the first package is "python3"
sudo mv python3* $HOME
### WARNING DON'T CLOSE THE SHELL DON'T DO ANYTHING AFTER THAT
Hey, listen here we are not removing the files but just moving them to some other location, So, in case anything bad happens we can still fix it as we have backup
Then test again
Again see the error message (most of the errors were gone after this)
Then do the same with all the error packages again (sudo mv error-package* $HOME)
So after doing the above all, You will see you can install and use apt packages
Now fix everything copy/paste this line (if you are in a try then you need to manually type this)
for package in $(apt-get upgrade 2>&1 | grep "warning: files list file for package '" | grep -Po "[^'\n ]+'" | grep -Po "[^']+"); do apt-get install --reinstall "$package"; done
if this didn't return anything run sudo apt install python3-all, you will still get an error message saying that files for package x are missing, don't bother that error
At last no matter, what happens, You need to run these commands.
MAKE SURE TO RUN-
sudo apt install aptitude
sudo aptitude -f upgrade
sudo aptitude -f install --reinstall ubuntu-session
sudo reboot
Now more it less your problem should be solved
Error404
  • 8,278
  • 35
  • 60
I would recommend to reinstall possibly problematic packages at low level:
cd ~/Downloads/debs
and then repeat above commands from smaller code block.
Do not try to remove files from /var/lib/dpkg/info/ - it is dangerous and may get situation even worse, up to completely reinstall.
N0rbert
  • 103,263
