So I decided to start using Ubuntu (Version 20.04) on my Macbook Pro one day, all was well until I tried to take a picture from my internal camera through Cheese.
The Cheese window is just a blank screen that says: 'No device found' And on any other video recording device that should have access to the camera shows a blank screen with no Input Capture from the camera.
I tried installing the Facetime HD camera drivers for running Ubuntu on a Macbook, but I ran into some errors and in the end, it didn't work.
The websites I tried following the directions are:
https://github.com/patjak/facetimehd/wiki/Get-Started#firmware-extraction https://github.com/patjak/facetimehd/wiki/Installation#get-started-on-ubuntu https://gist.github.com/johnjeffers/3006011ec7767a4101cdd118e8d64290 https://victorleungtw.medium.com/install-ubuntu-20-04-lts-on-macbookpro14-1-9f1b6afde43d
The Ubuntu uname -r outputs:
5.11.0-40-generic
None of the solutions on the GitHub websites work as I read every comment.
The only thing I think might be helpful from lspci is:
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] (rev c0)
Output of sudo lshw -c multimedia is (Shows no video device, if it helps)
*-multimedia
description: Audio device
product: Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0.1
bus info: pci@0000:01:00.1
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:80 memory:82660000-82663fff
*-multimedia
product: 100 Series/C230 Series Chipset Family HD Audio Controller
vendor: Intel Corporation
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 31
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=snd_hda_intel latency=64
resources: iomemory:400-3ff irq:79 memory:82720000-82723fff memory:4000000000-400000ffff
Thanks in advance.
