-2
 student@Ubuntu:/$ ls -l
    total 80
    drwxr-xr-x   1 root root 4096 May  9  2021 bin
    drwxr-xr-x   2 root root 4096 Apr 24  2018 boot
    drwxr-xr-x   5 root root  360 Nov 23 19:50 dev
    drwxr-xr-x   1 root root 4096 Nov 23 19:50 etc
    drwxr-xr-x   1 root root 4096 May  9  2021 home
    drwxr-xr-x   1 root root 4096 May  9  2021 lib
    drwxr-xr-x   2 root root 4096 Apr 16  2021 lib64
    drwxr-xr-x   2 root root 4096 Apr 16  2021 media
    drwxr-xr-x   2 root root 4096 Apr 16  2021 mnt
    drwxr-xr-x   1 root root 4096 May  9  2021 opt
    dr-xr-xr-x 167 root root    0 Nov 23 19:50 proc
    drwx------   1 root root 4096 May  9  2021 root
    drwxr-xr-x   1 root root 4096 May  9  2021 run
    drwxr-xr-x   1 root root 4096 May  9  2021 sbin
    drwxr-xr-x   2 root root 4096 Apr 16  2021 srv
    dr-xr-xr-x  13 root root    0 Nov 23 19:50 sys
    drwxrwxrwt   1 root root 4096 Nov 23 19:52 tmp
    drwxr-xr-x   1 root root 4096 Apr 16  2021 usr
    drwxr-xr-x   1 root root 4096 Apr 16  2021 var
    student@Ubuntu:/$ cd tmp
    student@Ubuntu:/tmp$ cat /var/log/auth.log
    cat: /var/log/auth.log: Permission denied
    student@Ubuntu:/tmp$ cd ..
    student@Ubuntu:/$ cd sys
    student@Ubuntu:/sys$ cat /var/log/auth.log
    student@Ubuntu:/sys$ chmod 777 sys
    chmod: cannot access 'sys': No such file or directory
    student@Ubuntu:/sys$ cd ..
    student@Ubuntu:/$ chmod 777 sys
    chmod: changing permissions of 'sys': Read-only file system
    student@Ubuntu:/$ chmod 777 var
    chmod: changing permissions of 'var': Operation not permitted
If you want to see the content of /var/log/auth.log you just need to make use of the sudo-command:
sudo cat /var/log/auth.log
will prompt you for your password and then display the content of the file.
Don't change permissions of system files, you'd easily end up with a reinstall of your operating system.
Alternatively you could add the user to the adm-group with
sudo adduser $USER adm
Followed by logout/login, groups are applied at login time.
This will make the use of the sudo-command unnecessary.
waltinator
  • 37,856
mook765
  • 18,644
