I'm trying to install Clang on Ubuntu 20.04 for ARM, which needs libobjc-9-dev. The Ubuntu 20.04 ARM repositories only have a version that needs GCC 9.3 but I currently have GCC 9.4 (trying to downgrade to GCC 9.3 leads to apt prompting me to uninstall x11 and xwayland).
I'm looking for a way to just grab a newer libobjc-9-dev but I can't find any links. I found this official website, and it says "You can download the requested file [...] at any of these sites:" but there are no sites listed after the colon. I also found this unofficial site and all the links for deb packages are for x86. The third link on Google is for another unofficial site that seems to have it except that the link for "Binary Package" points to an x86_64 package from Ubuntu. If I manually change "amd64" to "arm64" then the link doesn't work.
How do I download and install Clang and libobjc-9-dev? I've tried sudo apt install and the first three links on Google yet I'm unable to find an ARM version of libobjc-9-dev version 9.4.0-1ubuntu1~20.04 (to match Ubuntu's GCC version).
For the record, here is the message when trying to install libobjc-9-dev on Ubuntu 20.04 for ARM:
$ sudo apt install libobjc-9-dev
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libobjc-9-dev : Depends: gcc-9-base (= 9.3.0-17ubuntu1~20.04) but 9.4.0-1ubuntu1~20.04 is to be installed Depends: libgcc-9-dev (= 9.3.0-17ubuntu1~20.04) but 9.4.0-1ubuntu1~20.04 is to be installed
Aaron Franke
  • 1,136
