I'm trying to install wxWidgets, and on the installation guide they mention on Ubuntu I'd need the libgtk-3-dev package.
However, when I try to install it with
sudo apt-get install libgtk-3-dev
I get the following error:
Reading package lists...
Building dependency tree...
Reading state information...
The following packages have unmet dependencies: libgtk-3-dev : Depends: gir1.2-gtk-3.0 (= 3.24.18-1ubuntu1) but 3.24.20-0ubuntu1 is to be installed Depends: libatk-bridge2.0-dev but it is not going to be installed Depends: libcairo2-dev (>= 1.14.0) but it is not going to be installed Depends: libegl1-mesa-dev but it is not going to be installed Depends: libepoxy-dev (>= 1.0) but it is not going to be installed Depends: libfontconfig1-dev but it is not going to be installed Depends: libpango1.0-dev (>= 1.41) but it is not going to be installed Depends: libgtk-3-0 (= 3.24.18-1ubuntu1) but 3.24.20-0ubuntu1 is to be installed
And the command exits with the following error 100: E: Unable to correct problems, you have held broken packages.
What are the steps I need to take to correct this?
Set
  • 121
