I having trouble with running command: sudo apt-get update I have below errors. Do you have any ideas and suggestions, please? Thank you!
Err:2 http://es-mirrors.evowise.com/ubuntu impish InRelease
  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
Err:3 http://es-mirrors.evowise.com/ubuntu impish-updates InRelease
Err:4 http://es-mirrors.evowise.com/ubuntu impish-backports InRelease
Err:6 http://es-mirrors.evowise.com/ubuntu impish-security InRelease
Reading package lists... Done
N: See apt-secure(8) manpage for repository creation and user configuration details.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
E: The repository 'http://es-mirrors.evowise.com/ubuntu impish InRelease' is not signed.
E: Failed to fetch http://es-mirrors.evowise.com/ubuntu/dists/impish/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'http://es-mirrors.evowise.com/ubuntu impish-updates InRelease' is not signed.
E: Failed to fetch http://es-mirrors.evowise.com/ubuntu/dists/impish-updates/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: Failed to fetch http://es-mirrors.evowise.com/ubuntu/dists/impish-backports/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'http://es-mirrors.evowise.com/ubuntu impish-backports InRelease' is not signed.
E: Failed to fetch http://es-mirrors.evowise.com/ubuntu/dists/impish-security/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'http://es-mirrors.evowise.com/ubuntu impish-security InRelease' is not signed.
N0rbert
  • 103,263
1. Edit netplan File
sudo vi /etc/netplan50-cloud-init.yaml
2. Add Nameserver Google / Cloudflare or any, on nameserver
network:
    ethernets:
        [network-device]:
            nameservers:
                addresses:
                - 2001:4860:4860::8888
                - 2001:4860:4860::8844
                - 8.8.8.8
                - 8.8.4.4
                - 1.1.1.1
notes: don’t use tab on this file, only space allowed.
3. Apply and Test the Network
sudo netplan apply
systemd-resolve --status
References: https://josuamarcelc.com/cannot-sudo-apt-update-failed-to-update-ubuntu/
4. After that try again
sudo apt-get update
Josua M C
  • 101
