I have just installed Ubuntu 20.04 on my DELL 7240 and my WiFi adapter (Intel 7260) seems to be disabled.
I have tried different ways to enable it:
Edited the following file: sudo vi /etc/modprobe.d/iwlwifi.conf adding options iwlwifi 11n_disable=8, and then added also options iwlwifi 11n_disable=1. However, it didn't work after rebooting.
Continuing on reading from other posts, I have tried sudo apt install backport-iwlwifi-dkms which didn't work as well.
I have also downloaded the latest drivers for the Intel driver from https://anduin.linuxfromscratch.org/BLFS/linux-firmware and put under /lib/firmware/ directory, and then rebooted. Still, didn't work.
I have also tried to upgrade my kernel, and do update on everything. Still didn't work.
Output of lspci -knn | grep Net -A3; rfkill list :
02:00.0 Network controller [0280]: Intel Corporation Wireless 7260 [8086:08b1] (rev 73)
Subsystem: Intel Corporation Dual Band Wireless-AC 7260 [8086:4470]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi, wl
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
2: dell-wifi: Wireless LAN
Soft blocked: no
Hard blocked: yes
3: dell-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: yes
4: nfc0: NFC
Soft blocked: no
Hard blocked: no
The secure boot is disabled as well.
My kernel is 5.11.
Any ideas?
Regards, Evan
