After seeing this post: How do I increase swapfile in Ubuntu 18.04?, I was wondering, how do I decrease the size of the swap file without removing it?
Asked
Active
Viewed 5,683 times
This question is rather irrelevant. Swap space must be taken out of use before changing it. The command sudo fallocate -l 4G /swapfile (with an adjusted size) will overwrite your existing swapfile if you do not delete it first.
vanadium
- 97,564
