I got a segmentation fault while trying to install Python 3.5 on Ubuntu 21.10.
$ guettli@p15:~$ pyenv install 3.5.8
Downloading Python-3.5.8.tar.xz...
-> https://www.python.org/ftp/python/3.5.8/Python-3.5.8.tar.xz
Installing Python-3.5.8...
BUILD FAILED (Ubuntu 21.10 using python-build 20180424)
Inspect or clean up the working tree at /tmp/python-build.20211119144903.305257
Results logged to /tmp/python-build.20211119144903.305257.log
Last 10 log lines:
if test "xupgrade" != "xno" ; then
case upgrade in
upgrade) ensurepip="--upgrade" ;;
install|*) ensurepip="" ;;
esac;
./python -E -m ensurepip
$ensurepip --root=/ ;
fi
Segmentation fault (core dumped)
The same happens, when I install Python-3.5.10.tar.xz (without pyenv). What can I do now?
Version: Ubuntu 21.10
Output of configure: https://pastebin.com/rie17s8Z
Output of make: https://pastebin.com/F3C4evR6
Output of make install: https://paste2.org/LKxHUYkM
With PYTHONFAULTHANDLER:
guettli@p15:~/Downloads/Python-3.5.10$ PYTHONFAULTHANDLER=1 LANG=C python3.5 -m ensurepip
Fatal Python error: Segmentation fault
Current thread 0x00007fb703b40740 (most recent call first):
File "/usr/local/lib/python3.5/ctypes/init.py", line 276 in _reset_cache
File "/usr/local/lib/python3.5/ctypes/init.py", line 541 in <module>
File "<frozen importlib._bootstrap>", line 222 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 697 in exec_module
File "<frozen importlib._bootstrap>", line 673 in _load_unlocked
File "<frozen importlib._bootstrap>", line 957 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 968 in _find_and_load
File "/usr/local/lib/python3.5/uuid.py", line 464 in <module>
File "/tmp/tmppx73eqwt/pip-9.0.1-py2.py3-none-any.whl/pip/_vendor/requests/packages/urllib3/filepost.py", line 4 in <module>
File "<frozen importlib._bootstrap>", line 634 in _load_backward_compatible
File "<frozen importlib._bootstrap>", line 664 in _load_unlocked
File "/tmp/tmppx73eqwt/pip-9.0.1-py2.py3-none-any.whl/pip/_vendor/requests/packages/urllib3/request.py", line 7 in <module>
File "/tmp/tmppx73eqwt/pip-9.0.1-py2.py3-none-any.whl/pip/_vendor/requests/packages/urllib3/connectionpool.py", line 41 in <module>
File "/tmp/tmppx73eqwt/pip-9.0.1-py2.py3-none-any.whl/pip/_vendor/requests/packages/urllib3/init.py", line 8 in <module>
File "<frozen importlib._bootstrap>", line 1015 in _handle_fromlist
File "/tmp/tmppx73eqwt/pip-9.0.1-py2.py3-none-any.whl/pip/_vendor/requests/packages/init.py", line 27 in <module>
File "<frozen importlib._bootstrap>", line 943 in _find_and_load_unlocked
File "/tmp/tmppx73eqwt/pip-9.0.1-py2.py3-none-any.whl/pip/_vendor/requests/init.py", line 62 in <module>
File "/tmp/tmppx73eqwt/pip-9.0.1-py2.py3-none-any.whl/pip/init.py", line 21 in <module>
File "/usr/local/lib/python3.5/ensurepip/init.py", line 40 in _run_pip
File "/usr/local/lib/python3.5/ensurepip/init.py", line 116 in bootstrap
File "/usr/local/lib/python3.5/ensurepip/init.py", line 209 in _main
File "/usr/local/lib/python3.5/ensurepip/main.py", line 4 in <module>
File "/usr/local/lib/python3.5/runpy.py", line 85 in _run_code
File "/usr/local/lib/python3.5/runpy.py", line 193 in _run_module_as_main
