I want to be able to automatically terminate ssh connections that are idle for more than 10 minutes.
How do I do this?
David Oneill
  • 12,614
Open up terminal, Ctrl-Alt-T. Then:
  • sudo gedit /etc/ssh/sshd_config
  • Set (or modify) the following options:
    ClientAliveInterval 600
    ClientAliveCountMax 0
  • Save and exit the editor.
  • Run sudo service ssh restart
ClientAliveInterval sets the period after which, if the server sees the client as idle, it will send a "keep alive" request. If it gets no response, the client is disconnected. ClientAliveCountMax is the number of times such a keep alive is requested before disconnection. By setting it to 0, the keepalive is never sent and all clients idle for more than 10 minutes (600 seconds) are disconnected.
ish
  • 141,990
Edit /etc/ssh/sshd_config
sudo vim /etc/ssh/sshd_config
Add in this file the ClientAliveInterval option in seconds.
By the MAN page of sshd_config, that you can check here :
ClientAliveInterval: Sets a timeout interval in seconds after which if no data has been received from the client, sshd will send a message through the encrypted channel to request a response from the client. The default is 0, indicating that these messages will not be sent to the client. This option applies to protocol version 2 only.
