I was following this instruction for installing R 4.0 in Ubuntu 18.04
$ sudo apt remove r-base
$ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys E298A3A825C0D65DFD57CBB651716619E084DAB9
$ sudo add-apt-repository 'deb https://cloud.r-project.org/bin/linux/ubuntu bionic-cran40/'
$ sudo apt update
$ sudo apt install r-base
However I get this error message:
Reading package lists... Done
Building dependency tree
Package r-base is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  r-base-core r-doc-info r-doc-html r-base-html r-base-core:i386
E: Package 'r-base' has no installation candidate
I'm using this version of Ubuntu:
$ uname -a
Linux ip-172-31-28-209 5.4.0-1059-aws #62~18.04.1-Ubuntu SMP Fri Oct 22 21:51:38 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -cs bionic
How can I resolve the issue?
Update
$ sudo apt-cache policy r-base
r-base:
  Installed: (none)
  Candidate: (none)
  Version table:
     4.1.2-1.1804.0 -1
         -1 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran40/ Packages
     4.1.1-1.1804.0 -1
     4.1.0-1.1804.0 -1
     4.0.5-1.1804.0 -1
     4.0.4-1.1804.0 -1
     4.0.3-1.1804.0 -1
     4.0.2-1.1804.0 -1
     4.0.1-1.1804.0 -1
     4.0.0-1.1804.0 -1
     3.4.4-1ubuntu1 -1
         -1 http://ap-northeast-1.ec2.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
Update 2
$ sudo apt install r-base=4.1.2-1.1804.0
The following packages have unmet dependencies: r-base : Depends: r-base-core (>= 4.1.2-1.1804.0) but it is not installable Depends: r-recommended (= 4.1.2-1.1804.0) but it is not installable Recommends: r-base-html but it is not installable Recommends: r-doc-html but it is not installable E: Unable to correct problems, you have held broken packages.
Following suggestion by @user.dz, I ended up manually editing /etc/apt/preferences and replacing pin priority from -1 to 500
Package: *
Pin: release a=bionic*
Pin-Priority: 500
The Problem is :
  Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
  Executing: /tmp/apt-key-gpghome.D7jTjWc4gW/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys E298A3A825C0D65DFD57CBB651716619E084DAB9
  gpg: key 51716619E084DAB9: "Michael Rutter <marutter@gmail.com>" 1 new signature
  gpg: Total number processed: 1
  gpg:         new signatures: 1
When you run apt-key the keyserver is deprecated on /tmp/ like my case. The Ubuntu archives on CRAN are signed with the key of Michael Rutter marutter@gmail.com with key ID 0x51716619e084dab9. To add the key to your system with one command use
Recommended method :
$ wget -qO- https://cloud.r-project.org/bin/linux/ubuntu/marutter_pubkey.asc | sudo tee -a /etc/apt/trusted.gpg.d/cran_ubuntu_key.asc
$ sudo add-apt-repository "deb https://cloud.r-project.org/bin/linux/ubuntu $(lsb_release -cs)-cran40/"
$ sudo apt update
$ sudo apt install --no-install-recommends r-base
Hope this helps.
Related
-1
Given you get the message:
I am going to say perhaps r-base-core.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
David
