I use Ubuntu 20.04, the problem is the Files app in the system does not open. I tried different method such as reinstalling nautilus, its data. But non of it seems to work as in I still cannot open the app. I tried changing the permissions of the home directory as well but that didn't work out either. This all started when I installed OBS. But I uninstalled that as well. links to the post I referred : "Files" File manager is not working on Ubuntu 20.04 I tried everything from this post but non of that worked for me so please can anyone help me
i tried this line to reinstall nautilus
sudo apt-get remove nautilus
sudo apt-get install nautilus
then I tried to reinstall its data
sudo apt-get install --reinstall nautilus-data
and the above lines gave a successful message yet only
sudo nautilus
worked but only showed me the root and efi. As you can clearly see that only efi and root are visible Photo
So I went forward and did the change permission thing of the home directory so i did that to the home folder in the root drive. And one more thing to note is whenever i try to launch the nautilus my swap memory suddenly rises and the system slows for about a minute. Despite the fact that i have 12Gb of physical memory but during that time only 1 Gb is used and around 26% to 45% of swap is used.
Samarth
