I alwais have a not charging icon in the top bar. This is the output of upower -d when laptop is plugged in:
Device: /org/freedesktop/UPower/devices/line_power_AC0
  native-path:          AC0
  power supply:         yes
  updated:              mar 16 nov 2021 20:44:16 (90 seconds ago)
  has history:          no
  has statistics:       no
  line-power
    warning-level:       none
    online:              yes
    icon-name:          'ac-adapter-symbolic'
Device: /org/freedesktop/UPower/devices/battery_BAT0 native-path: BAT0 vendor: ASUSTeK model: ASUS Battery power supply: yes updated: mar 16 nov 2021 20:44:16 (90 seconds ago) has history: yes has statistics: yes battery present: yes rechargeable: yes state: pending-charge warning-level: none energy: 57,252 Wh energy-empty: 0 Wh energy-full: 58,741 Wh energy-full-design: 66 Wh energy-rate: 0 W voltage: 15,677 V percentage: 97% capacity: 89,0015% technology: lithium-ion icon-name: 'battery-full-charging-symbolic' History (charge): 1637091856 0,000 unknown History (rate): 1637091856 0,000 unknown
Device: /org/freedesktop/UPower/devices/DisplayDevice power supply: yes updated: mar 16 nov 2021 20:44:16 (90 seconds ago) has history: no has statistics: no battery present: yes state: pending-charge warning-level: none energy: 57,252 Wh energy-full: 58,741 Wh energy-rate: 0 W percentage: 97% icon-name: 'battery-full-charging-symbolic'
Daemon: daemon-version: 0.99.11 on-battery: no lid-is-closed: no lid-is-present: yes critical-action: HybridSleep
Meanwhile the laptop seems is not discharging, always on 97%
The pending-charge state means AC power is on but the battery is not being charged. This can happen because its charge is above a certain threshold, to avoid short charging cycles and prolong the battery's life, or because the PSU is not powerful enough to charge the batteries.
bfday
if you are here because you are afraid of "my charger is not working!" and your battery level is "low", then relax, just give it few minuets and it shows "charging". Let's leave technical discussion behind ... :-D
