So I'm fairly new to Docker and Ubuntu and I'm trying to create a mail server by following this tutorial in Youtube. But I'm unable to do so because I keep getting some errors. And I don't know what each of these mean. I am also following the official docs from Docker website to install docker in Ubuntu and here are the output I get from each commands:
sudo apt-get install ca-certificates curl gnupg lsb-release
Reading package lists... Done Building dependency tree Reading state information... Done ca-certificates is already the newest version (20210119~20.04.2). curl is already the newest version (7.68.0-1ubuntu2.7). gnupg is already the newest version (2.2.19-3ubuntu2.1). lsb-release is already the newest version (11.1.0ubuntu2). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
File '/usr/share/keyrings/docker-archive-keyring.gpg' exists. Overwrite? (y/N) y
echo \
  "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu \
  $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
Get:1 https://download.docker.com/linux/ubuntu focal InRelease [57.7 kB]
Err:1 https://download.docker.com/linux/ubuntu focal InRelease
  Couldn't create temporary file /tmp/apt.conf.EhsiyX for passing config to apt-key
Ign:2 http://rpms.litespeedtech.com/debian focal InRelease
Get:3 http://rpms.litespeedtech.com/debian focal Release [1,646 B]
Get:4 https://deb.nodesource.com/node_14.x focal InRelease [4,583 B]
Get:5 http://rpms.litespeedtech.com/debian focal Release.gpg [836 B]
Err:4 https://deb.nodesource.com/node_14.x focal InRelease
  Couldn't create temporary file /tmp/apt.conf.cJQw53 for passing config to apt-key
Ign:5 http://rpms.litespeedtech.com/debian focal Release.gpg
Get:6 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Ign:7 http://ppa.launchpad.net/certbot/certbot/ubuntu focal InRelease
Get:8 http://us.archive.ubuntu.com/ubuntu focal InRelease [265 kB]
Err:6 http://security.ubuntu.com/ubuntu focal-security InRelease
  Couldn't create temporary file /tmp/apt.conf.H2ZQrn for passing config to apt-key
Err:9 http://ppa.launchpad.net/certbot/certbot/ubuntu focal Release
  404  Not Found [IP: 91.189.95.85 80]
Err:8 http://us.archive.ubuntu.com/ubuntu focal InRelease
  Couldn't create temporary file /tmp/apt.conf.TKkNRz for passing config to apt-key
Get:10 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Err:10 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
  Couldn't create temporary file /tmp/apt.conf.kdYADH for passing config to apt-key
Get:11 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
Err:11 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
  Couldn't create temporary file /tmp/apt.conf.Z56AhL for passing config to apt-key
W: GPG error: https://download.docker.com/linux/ubuntu focal InRelease: Couldn't create temporary file /tmp/apt.conf.EhsiyX for passing config to apt-key
E: The repository 'https://download.docker.com/linux/ubuntu focal InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: https://deb.nodesource.com/node_14.x focal InRelease: Couldn't create temporary file /tmp/apt.conf.cJQw53 for passing config to apt-key
E: The repository 'https://deb.nodesource.com/node_14.x focal InRelease' is not signed.
W: GPG error: http://rpms.litespeedtech.com/debian focal Release: Couldn't create temporary file /tmp/apt.conf.mT1cgh for passing config to apt-key
E: The repository 'http://rpms.litespeedtech.com/debian focal Release' is not signed.
W: GPG error: http://security.ubuntu.com/ubuntu focal-security InRelease: Couldn't create temporary file /tmp/apt.conf.H2ZQrn for passing config to apt-key
E: The repository 'http://security.ubuntu.com/ubuntu focal-security InRelease' is not signed.
E: The repository 'http://ppa.launchpad.net/certbot/certbot/ubuntu focal Release' does not have a Release file.
W: GPG error: http://us.archive.ubuntu.com/ubuntu focal InRelease: Couldn't create temporary file /tmp/apt.conf.TKkNRz for passing config to apt-key
E: The repository 'http://us.archive.ubuntu.com/ubuntu focal InRelease' is not signed.
W: GPG error: http://us.archive.ubuntu.com/ubuntu focal-updates InRelease: Couldn't create temporary file /tmp/apt.conf.kdYADH for passing config to apt-key
E: The repository 'http://us.archive.ubuntu.com/ubuntu focal-updates InRelease' is not signed.
W: GPG error: http://us.archive.ubuntu.com/ubuntu focal-backports InRelease: Couldn't create temporary file /tmp/apt.conf.Z56AhL for passing config to apt-key
E: The repository 'http://us.archive.ubuntu.com/ubuntu focal-backports InRelease' is not signed.
W: Target Packages (stable/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:62 and /etc/apt/sources.list.d/docker.list:1
W: Target Packages (stable/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:62 and /etc/apt/sources.list.d/docker.list:1
W: Target Translations (stable/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:62 and /etc/apt/sources.list.d/docker.list:1
W: Target Translations (stable/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:62 and /etc/apt/sources.list.d/docker.list:1
W: Target CNF (stable/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:62 and /etc/apt/sources.list.d/docker.list:1
W: Target CNF (stable/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:62 and /etc/apt/sources.list.d/docker.list:1
sudo apt-get install docker-ce docker-ce-cli containerd.io
E: Unable to locate package docker-ce
E: Unable to locate package docker-ce-cli
E: Unable to locate package containerd.io
E: Couldn't find any package by glob 'containerd.io'
E: Couldn't find any package by regex 'containerd.io'
These are all the outputs I am getting and I don't know what else I should do or try but I badly need to setup my mail server. Someone please help me out. It'd be a big help.
UPDATE
So after contacting support they have restored the server to a previous working state. Then I updated/upgraded with sudo apt update and sudo apt upgrade. It completed but then after I tried running update again and I get this:
@server1:~$ sudo apt update
Hit:1 https://deb.nodesource.com/node_14.x focal InRelease
Ign:2 http://ppa.launchpad.net/certbot/certbot/ubuntu focal InRelease
Err:3 http://ppa.launchpad.net/certbot/certbot/ubuntu focal Release
Hit:4 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:6 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:7 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
I think something is wrong with the new updates and all.
Zak
  • 121
