13
I wanted to install Temurin JDK both 8 and 11, I installed them by these steps
wget https://github.com/adoptium/temurin8-binaries/releases/download/jdk8u312-b07/OpenJDK8U-jdk_x64_linux_hotspot_8u312b07.tar.gz
tar xzf OpenJDK8U-jdk_x64_linux_hotspot_8u312b07.tar.gz
sudo mv jdk8u312-b07/ /usr/lib/jvm/temurinjdk-8-hotspot-amd64
sudo update-alternatives --install "/usr/bin/java" "java" "/usr/lib/jvm/temurinjdk-8-hotspot-amd64/bin/java" 1081 sudo update-alternatives --install "/usr/bin/javac" "javac" "/usr/lib/jvm/temurinjdk-8-hotspot-amd64/bin/javac" 1081
But I am not sure if this is 100% right and how do I generate .jinfo file is that even needed?
poqdavid
  • 277
You can use the Adoptium Debian / Ubuntu repository
  1. Add the Eclipse Adoptium GPG key
    wget -O - https://packages.adoptium.net/artifactory/api/gpg/key/public | sudo apt-key add -
  2. Add the Eclipse Adoptium apt repository
    echo "deb https://packages.adoptium.net/artifactory/deb $(awk -F= '/^VERSION_CODENAME/{print$2}' /etc/os-release) main" | sudo tee /etc/apt/sources.list.d/adoptium.list
  3. Install the Temurin version you require
    sudo apt update # update if you haven't already
    sudo apt install temurin-8-jdk
    sudo apt install temurin-17-jdk
    sudo apt install temurin-21-jdk
  4. Configure the default version
    sudo update-alternatives --config java
BuZZ-dEE
  • 14,533
I extracted script from original AdoptOpenJDK deb package and modified version I use like:
wget https://github.com/adoptium/temurin17-binaries/releases/download/jdk-17.0.1%2B12/OpenJDK17U-jdk_x64_linux_hotspot_17.0.1_12.tar.gz
mkdir -p /usr/lib/jvm
sudo tar -xvvf OpenJDK17U-jdk_x64_linux_hotspot_17.0.1_12.tar.gz -C /usr/lib/jvm/
sudo ./java-alternative install /usr/lib/jvm/jdk-17.0.1+12 sudo ./java-alternative set /usr/lib/jvm/jdk-17.0.1+12 … sudo ./java-alternative remove /usr/lib/jvm/jdk-17.0.1+12
Source code of script:
#!/bin/sh
set -eu
priority=2222 #jdk_base_dir=/usr/lib/jvm/adoptopenjdk-11-hotspot-amd64 #jdk_base_dir=/usr/lib/jvm/jdk-17.0.1+12 jdk_base_dir="$2"
if [ ! -d "$jdk_base_dir" ] then echo "Invalid java directory. Choose one of: "; ls -1d /usr/lib/jvm/* exit fi
tools="jaotc jar jarsigner java javac javadoc javap jcmd jconsole jdb jdeprscan jdeps jfr jhsdb jimage jinfo jjs jlink jmap jmod jps jrunscript jshell jstack jstat jstatd keytool pack200 rmic rmid rmiregistry serialver unpack200 jexec jspawnhelper"
case "$1" in install) for tool in $tools ; do for tool_path in "$jdk_base_dir/bin/$tool" "$jdk_base_dir/lib/$tool" ; do if [ ! -e "$tool_path" ]; then continue fi
        slave=""
        tool_man_path="$jdk_base_dir/man/man1/$tool.1"
        if [ -e "$tool_man_path" ]; then
            slave="--slave /usr/share/man/man1/$tool.1 $tool.1 $tool_man_path"
        fi
        update-alternatives \
            --install \
            "/usr/bin/$tool" \
            "$tool" \
            "$tool_path" \
            "$priority" \
            $slave
    done
done
;; remove) for tool in $tools ; do for tool_path in "$jdk_base_dir/bin/$tool" "$jdk_base_dir/lib/$tool" ; do if [ ! -e "$tool_path" ]; then continue fi
            --remove \
            "$tool" \
            "$tool_path"
    done
done
;; set) for tool in $tools ; do for tool_path in "$jdk_base_dir/bin/$tool" "$jdk_base_dir/lib/$tool" ; do if [ ! -e "$tool_path" ]; then continue fi
            --set \
            "$tool" \
            "$tool_path"
    done
done
;; esac
