I want to install Python 3.10 on Ubuntu 18.04 (I'm currently on Python 3.8) from the deadsnakes repository with the following set of commands I found on the internet:
sudo add-apt-repository ppa:deadsnakes/ppa
sudo apt update
sudo apt install python3.10
But I got the error "sudo: add-apt-repository: command not found."
More net research led me to this set of commands at "ModuleNotFoundError: No module named 'apt_pkg'" appears in various commands:
sudo apt remove python3-apt
sudo apt autoremove
sudo apt autoclean
sudo apt install python3-apt
Other web sources said the same thing, so I did that, but I still get the error message when I run sudo add-apt-repository ppa:deadsnakes/ppa.
Then I found https://phoenixnap.com/kb/add-apt-repository-command-not-found-ubuntu, which advised this set of commands:
sudo apt update
sudo apt install software-properties-common
sudo apt update
so I did that, but when I run sudo add-apt-repository ppa:deadsnakes/ppa I now get this error message:
~$ sudo add-apt-repository ppa:deadsnakes/ppa Traceback (most recent call last): File "/usr/bin/add-apt-repository", line 12, in from softwareproperties.SoftwareProperties import SoftwareProperties, shortcut_handler File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 28, in import apt_pkg ModuleNotFoundError: No module named 'apt_pkg'
I have found some web links that show a wide variety of solutions with earlier versions of Python. I'm currently on Python 3.8.
Before I do anything more I want to ask what is the best way to solve the ModuleNotFoundError: No module named 'apt_pkg' error message when trying to install the deadsnakes repository to install Python 3.10, given the number of possible solutions I have seen. Is there another way of installing 3.10 other than building from source?
Thanks very much.
RTC222
  • 267
