I want to make my laptop (with legacy bios) be able to dual boot ubuntu and windows 10, so I make a bootable usb following the official guide with rufus. However I can never go past the boot screen. I tried to find past solution to this problem, but I can't seem to find any. I always stuck on boot, never be able to go past it even with using nomodeset and different ubuntu flavors. I always stuck on this line
systemd[1]: Inserted module 'autofs4'
even when I waited for 30 minutes it never got to the desktop
It looks like your laptop can't handle the reading of your usb-stick (AHCI Problem). Check your bios, if you can change anything concerning the "boot from USB", else try another stick.
Also make sure, that your iso checksum is correct - here is how to do it
kanehekili
  • 7,426
Select 'dd-mode' in Rufus and try again
dd-mode means that Rufus will clone from the iso file to the USB drive (instead of the more complicated creation of partition table, file system, bootloader and extraction of the content from the iso file to the file system in the USB drive.
Cloning means that every byte of the iso file is copied as it is to the target drive, and it is a robust process, very likely to succeed, and cloning makes all Ubuntu family iso files bootable both in UEFI mode and legacy mode (alias CSM alias BIOS mode).
sudodus
  • 47,684
