I have downloaded PIA for Ubuntu from the official PIA site. When it downloads it is in a .run file There are no instructions on how to install PIA on my 21.04 system.
Can anyone help?
PIA does a pretty good job of hiding the install instructions, they can be found here: https://www.privateinternetaccess.com/helpdesk/guides/linux/linux-installing-the-pia-app#linux-installing-the-pia-app_step-1-download
It's actually pretty simple:
Open a terminal
Move to the directory containing the .run file:
$ cd Downloads
Run the file using sh (do not use sudo) and enter your password when prompted:
$ sh pia-linux-3.1-06756.run
The app should automatically open when the script finishes. Log in with your PIA credentials and you'll be good to go.
You may have to make the file executable, in which case run this command before running the .run file:
$ sudo chmod u+x /path/to/pia-linux-3.1-06756.run
Thanks, I do agree that they do a good job at trying to hide their installer.
I have just discovered an easier way to install it.
Open a terminal
Drag and drop the .run file its download location into the terminal
Press return.
Worked for me :-)
