Yesterday i tried to install mysql-workbench on Ubuntu 20.04 and the installation failed. The problem is that some packages installed with unmet dependencies:
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libmysqlclient21 : Depends: mysql-common (>= 8.0.27-1ubuntu21.10) but 5.8+1.0.5ubuntu2 is installed
Depends: mysql-community-client-plugins (= 8.0.27-1ubuntu21.10) but it is not installable
Depends: libc6 (>= 2.34) but 2.31-0ubuntu9.2 is installed
Depends: libstdc++6 (>= 11) but 10.3.0-1ubuntu1~20.04 is installed
mysql-workbench-community : Depends: libopengl0 but it is not installed
Depends: libproj15 (>= 6.3.0) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried the recommended command:
sudo apt --fix-broken install
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
And then i tried some commands that i found:
sudo dpkg -r libmysqlclient21
dpkg: dependency problems prevent removal of libmysqlclient21:amd64:
mysql-workbench-community depends on libmysqlclient21 (>= 8.0.11).
libsnmp35:amd64 depends on libmysqlclient21 (>= 8.0.11).
dpkg: error processing package libmysqlclient21:amd64 (--remove):
dependency problems - not removing
sudo dpkg -r mysql-common
dpkg: dependency problems prevent removal of mysql-common:
libmysqlclient21:amd64 depends on mysql-common (>= 8.0.27-1ubuntu21.10).
dpkg: error processing package mysql-common (--remove):
mysql-common
sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of mysql-workbench-community:
mysql-workbench-community depends on libmysqlclient21 (>= 8.0.11); however:
Package libmysqlclient21:amd64 is not configured yet.
mysql-workbench-community depends on libopengl0; however:
Package libopengl0 is not installed.
mysql-workbench-community depends on libproj15 (>= 6.3.0); however:
Package libproj15 is not installed.
dpkg: error processing package mysql-workbench-community (--configure):
dependency problems - leaving unconfigured
But as you can see nothing worked for me. Please somebody help me because i can't understand what is going wrong.
==============================Edited=================================
sudo apt update
Hit:1 http://gr.archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://gr.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:3 http://dl.google.com/linux/chrome/deb stable InRelease [1,811 B]
Get:4 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:5 http://gr.archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
Get:6 http://dl.google.com/linux/chrome/deb stable/main amd64 Packages [1,097 B]
Get:7 http://gr.archive.ubuntu.com/ubuntu focal-updates/main i386 Packages [562 kB]
Get:8 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages [987 kB]
Get:9 http://gr.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1,344 kB]
Get:10 http://gr.archive.ubuntu.com/ubuntu focal-updates/main Translation-en [276 kB]
Get:11 http://gr.archive.ubuntu.com/ubuntu focal-updates/main amd64 DEP-11 Metadata [279 kB]
Get:12 http://gr.archive.ubuntu.com/ubuntu focal-updates/main DEP-11 48x48 Icons [60.8 kB]
Get:13 http://gr.archive.ubuntu.com/ubuntu focal-updates/main DEP-11 64x64 Icons [98.3 kB]
Get:14 http://gr.archive.ubuntu.com/ubuntu focal-updates/main amd64 c-n-f Metadata [14.4 kB]
Get:15 http://gr.archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [569 kB]
Get:16 http://security.ubuntu.com/ubuntu focal-security/main i386 Packages [306 kB]
Get:17 http://gr.archive.ubuntu.com/ubuntu focal-updates/restricted i386 Packages [21.7 kB]
Get:18 http://gr.archive.ubuntu.com/ubuntu focal-updates/restricted Translation-en [81.6 kB]
Get:19 http://gr.archive.ubuntu.com/ubuntu focal-updates/restricted amd64 c-n-f Metadata [528 B]
Get:20 http://gr.archive.ubuntu.com/ubuntu focal-updates/universe i386 Packages [647 kB]
Get:21 http://security.ubuntu.com/ubuntu focal-security/main Translation-en [183 kB]
Get:22 http://security.ubuntu.com/ubuntu focal-security/main amd64 DEP-11 Metadata [29.0 kB]
Get:23 http://security.ubuntu.com/ubuntu focal-security/main amd64 c-n-f Metadata [8,844 B]
Get:24 http://security.ubuntu.com/ubuntu focal-security/restricted i386 Packages [20.4 kB]
Get:25 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [526 kB]
Get:26 http://gr.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [875 kB]
Get:27 http://gr.archive.ubuntu.com/ubuntu focal-updates/universe Translation-en [189 kB]
Get:28 http://gr.archive.ubuntu.com/ubuntu focal-updates/universe amd64 DEP-11 Metadata [357 kB]
Get:29 http://security.ubuntu.com/ubuntu focal-security/restricted Translation-en [75.4 kB]
Get:30 http://gr.archive.ubuntu.com/ubuntu focal-updates/universe DEP-11 48x48 Icons [217 kB]
Get:31 http://gr.archive.ubuntu.com/ubuntu focal-updates/universe DEP-11 64x64 Icons [385 kB]
Get:32 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 c-n-f Metadata [528 B]
Get:33 http://security.ubuntu.com/ubuntu focal-security/universe i386 Packages [515 kB]
Get:34 http://gr.archive.ubuntu.com/ubuntu focal-updates/universe amd64 c-n-f Metadata [19.5 kB]
Get:35 http://gr.archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [24.5 kB]
Get:36 http://gr.archive.ubuntu.com/ubuntu focal-updates/multiverse i386 Packages [8,204 B]
Get:37 http://gr.archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 DEP-11 Metadata [940 B]
Get:38 http://gr.archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 c-n-f Metadata [616 B]
Get:39 http://gr.archive.ubuntu.com/ubuntu focal-backports/universe i386 Packages [5,528 B]
Get:40 http://gr.archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages [6,584 B]
Get:41 http://gr.archive.ubuntu.com/ubuntu focal-backports/universe amd64 DEP-11 Metadata [10.4 kB]
Get:42 http://gr.archive.ubuntu.com/ubuntu focal-backports/universe DEP-11 64x64 Icons [5,608 B]
Get:43 http://gr.archive.ubuntu.com/ubuntu focal-backports/universe amd64 c-n-f Metadata [580 B]
Get:44 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages [651 kB]
Get:45 http://security.ubuntu.com/ubuntu focal-security/universe Translation-en [107 kB]
Get:46 http://security.ubuntu.com/ubuntu focal-security/universe amd64 DEP-11 Metadata [63.6 kB]
Get:47 http://security.ubuntu.com/ubuntu focal-security/universe amd64 c-n-f Metadata [12.8 kB]
Get:48 http://security.ubuntu.com/ubuntu focal-security/multiverse i386 Packages [7,212 B]
Get:49 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [21.9 kB]
Get:50 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 DEP-11 Metadata [2,464 B]
Get:51 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 c-n-f Metadata [540 B]
Fetched 9,908 kB in 8s (1,293 kB/s)
33 packages can be upgraded. Run 'apt list --upgradable' to see them.
==========================Listed Packages============================
sudo apt list --installed | grep mysql
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libmysqlclient21/now 8.0.27-1ubuntu21.10 amd64 [installed,local]
mysql-common/now 5.8+1.0.5ubuntu2 all [installed,local]
mysql-workbench-community/now 8.0.27-1ubuntu20.04 amd64 [installed,local]
Thank you in advance. Omiros Athanasakis
