I just switched from Windows to Ubuntu 20.04. My download speed went down from 30 Mbps to 1 Mbps. I can't even watch a youtube video at 720p. Are there any solutions to this? Also, I noticed after I connect to my wifi, it is fast the first 2 minutes and then it slows down again. I don't want to have to disconnect and connect to my wifi every 2 minutes.
*-network
       description: Ethernet interface
       product: RTL810xE PCI Express Fast Ethernet controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 05
       serial: b8:70:f4:d5:8c:bf
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.11.0-40-generic firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=twisted pair
       resources: irq:16 ioport:e000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
  *-network
       description: Wireless interface
       product: RTL8188CE 802.11b/g/n WiFi Adapter
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 01
       serial: 74:de:2b:2e:5c:91
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192ce driverversion=5.11.0-40-generic firmware=N/A ip=192.168.0.12 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:17 ioport:d000(size=256) memory:f7c00000-f7c03fff
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 04f2:b1d6 Chicony Electronics Co., Ltd CNF9055 Toshiba Webcam
Bus 001 Device 003: ID 0bda:0138 Realtek Semiconductor Corp. RTS5138 Card Reader Controller
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
I should mention I'm just a normie who switched to Linux so I can use OpenGL 3.3.
