I need to do Multiseat on computers at work, but I don't understand anything about it or ubuntu/linux, I would like to have an easy tutorial to follow, I read a little bit about LightDM (but I still don't understand much).
  • The computers must have 2 seats.
  • 2 monitors for each seat.
  • The computers have integrated intel video and 1 video card
Is it possible to multiseat? if yes, how?
hyoshi
  • 31
The short answer is yes, this will work. I have seen come computers that disable the onboard video when you plug in a video card, and others that allow the use of both devices. I have one here with an Intel onboard, and an AMD video card(you did not specify yours) and both video are working.
To be brief, in order to create multiseat set one video (onboard or pci-e, it should not matter) to seat zero and set the other for seat one. The only requirement for creating seats is the video card itself.
One option for creating seats is to use loginctl on the terminal to do the seat assignments.
Another option for creating seats is to use EasySeats, which is a little UI built with Java that makes issuing commands unnecessary.
ezst036
  • 116
