13
I don't want anyone to be able to shut down my computer from the login screen. Can I remove the shutdown button at the top right corner of the login screen in Ubuntu 12.04?
mfisch
  • 3,693
Richard
  • 139
Even if you cannot hide the buttons, you can configure your system so that the lightdm user does not have permissions to shutdown or restart the system. Since the greeter runs as the lightdm user, this should solve your issue. Create two new files in /var/lib/polkit-1/localauthority/50-local.d, call them disable-lightdm-shutdown.pkla and disable-lightdm-restart.pkla and apply the contents as below. Note: You can also stick these into one file.
Shutdown:
[Disable Shutdown]
Identity=unix-user:lightdm
Action=org.freedesktop.consolekit.system.stop
ResultAny=no
ResultInactive=no
ResultActive=no
Restart:
[Disable Restart]
Action=org.freedesktop.consolekit.system.restart
ResultAny=no
ResultInactive=no
ResultActive=no
Eliah Kagan
  • 119,640
mfisch
  • 3,693
Go to /etc/lightdm/lightdm-gtk-greeter.conf and edit it to contain
indicators=false
This will remove all indicator from login page.
Byte Commander
  • 110,243
Curious
  • 19
There aren't any configuration tools for LightDM that I know of, and if there are, there certainly wouldn't be any way to remove that button.
Unless you want to rewrite LightDM yourself.
One could alway try modifying the /usr/share/lightdm-gtk-greeter/greeter.ui file (available in Debian 7, at least).
Digger
  • 176
