When I plug my Pendrive I hear the sound of it getting detected.
output of dmesg
[21145.916189] usb 1-1: new high-speed USB device number 11 using xhci_hcd
[21146.522765] usb 1-1: New USB device found, idVendor=058f, idProduct=1234, bcdDevice= 0.01
[21146.522779] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[21146.522784] usb 1-1: Product: Mass Storage Device
[21146.522789] usb 1-1: Manufacturer: Alcor Micro
[21146.526401] usb-storage 1-1:1.0: USB Mass Storage device detected
[21146.526992] scsi host1: usb-storage 1-1:1.0
[21147.528953] scsi 1:0:0:0: Direct-Access Generic USB Flash Disk 7.76 PQ: 0 ANSI: 4
[21147.529520] sd 1:0:0:0: Attached scsi generic sg0 type 0
[21147.589044] sd 1:0:0:0: [sda] Attached SCSI removable disk
lsusb output
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0b05:1866 ASUSTek Computer, Inc. N-KEY Device
Bus 001 Device 010: ID 413c:301a Dell Computer Corp. Dell MS116 USB Optical Mouse
Bus 001 Device 004: ID 8087:0aaa Intel Corp.
Bus 001 Device 011: ID 058f:1234 Alcor Micro Corp. Flash Drive
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I am not sure why the pendrive is not showing up. Also it is not visible in gparted. what might have gone wrong.
sudo fdisk -l output
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 55.51 MiB, 58191872 bytes, 113656 sectors
Disk /dev/loop2: 128.85 MiB, 135090176 bytes, 263848 sectors
Disk /dev/loop3: 55.45 MiB, 58130432 bytes, 113536 sectors
Disk /dev/loop4: 65.1 MiB, 68259840 bytes, 133320 sectors
Disk /dev/loop5: 50.98 MiB, 53432320 bytes, 104360 sectors
Disk /dev/loop6: 32.42 MiB, 33980416 bytes, 66368 sectors
Disk /dev/loop7: 65.22 MiB, 68378624 bytes, 133552 sectors
Disk /dev/nvme0n1: 953.89 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: INTEL SSDPEKNW010T8
Disklabel type: gpt
Disk identifier: 0AED2D84-4932-4AF4-A2B3-C9F4134C44A3
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 534527 532480 260M EFI System
/dev/nvme0n1p2 534528 567295 32768 16M Microsoft reserved
/dev/nvme0n1p3 567296 419997695 419430400 200G Microsoft basic data
/dev/nvme0n1p4 419997696 836227071 416229376 198.5G Microsoft basic data
/dev/nvme0n1p5 836227072 1255657471 419430400 200G Microsoft basic data
/dev/nvme0n1p6 1255657472 1570230271 314572800 150G Microsoft basic data
/dev/nvme0n1p7 1999077376 2000408575 1331200 650M Windows recovery environment
/dev/nvme0n1p8 1570230272 1999077375 428847104 204.5G Linux filesystem
Partition table entries are not in disk order.
Disk /dev/loop8: 32.45 MiB, 34017280 bytes, 66440 sectors
Disk /dev/loop9: 218.102 MiB, 229629952 bytes, 448496 sectors
Disk /dev/loop10: 162.89 MiB, 170778624 bytes, 333552 sectors
Disk /dev/loop11: 164.78 MiB, 172761088 bytes, 337424 sectors
Disk /dev/loop12: 219 MiB, 229638144 bytes, 448512 sectors
Disk /dev/loop13: 50.98 MiB, 53432320 bytes, 104360 sectors
output of lsblk -f
nvme0n1
├─nvme0n1p1 vfat SYSTEM 88CB-E8E2 222.6M 13% /boot/efi
├─nvme0n1p2
├─nvme0n1p3 ntfs OS 4A84CDA084CD8F3F
├─nvme0n1p4 ntfs Documents 3214B0F814B0C061
├─nvme0n1p5 ntfs Software 24B6273DB6270F3C 41.4G 79% /home/USER/ssds
├─nvme0n1p6 ntfs General 0C4E38684E384D28 2.5G 98% /media/USER/General
├─nvme0n1p7 ntfs 36F054AEF0547659
└─nvme0n1p8 ext4 942a77ae-27b6-4e4d-80c5-e35a46b8661b 43.1G 73% /
