I have just done a fresh install of Ubuntu 21.10 for Raspberry Pi ARM64 in order to try out the new release.
After performing an apt upgrade and updating the iscsi initiator name I tried to run
sudo iscsiadm --mode discovery --type sendtargets --portal 10.1.0.20
but I got the following error
iscsiadm: read error (-1/104), daemon died?
iscsiadm: Could not scan /sys/class/iscsi_transport.
libkmod: ERROR ../libkmod/libkmod-module.c:838 kmod_module_insert_module: could not
find module by name='iscsi_tcp'
iscsiadm: Could not insert module tcp. Kmod error -2
iscsiadm: iSCSI driver tcp is not loaded. Load the module then retry the command.
iscsiadm: Could not perform SendTargets discovery: iSCSI driver not found. Please make sure it is loaded, and retry the operation
modprobe iscsi_tcp shows
modprobe: FATAL: Module iscsi_tcp not found in directory /lib/modules/5.13.0-1008-raspi
How can I enable / install / compile this missing kernel module?
It is included in linux-modules-extra-*-raspi packages.
Similar issue may solved by checking Package Search online or apt-file offline (but it needs to download big index files) and search the missing file.
user.dz
  • 49,176
EVERY KERNEL UPGRADE BREAKS iSCSI:
It's extremely important to note that the Accepted answer is NOT a fix-n-forget solution:
The package reference in the Accepted answer does fix the problem, but by installing a static Kernel Module. So once the Kernel is updated, the static Kernel Module is lost and you'll be back where you started: with broken iSCSI.
So after every Kernel upgrade you must remember to execute:
apt-get install linux-modules-extra-$(uname -r)
(tested with 'ubuntu-22.04-preinstalled-server-arm64+raspi.img.xz')
If you forget, you will be scratching your head wondering when your iSCSI is hosed ;-)
Finally:
Don't forget to do the housekeeping:
Find obsolete package:
dpkg -l | grep linux-modules-extra*
Remove it:
sudo apt-get remove linux-modules-extra-Prev-Pkg-Version-raspi
HTH-
F1Linux
  • 1,256
