Im a new Linux user and I am facing this problem with my install. To be very specific, I have tried Ubuntu, Mint and even Kubuntu but this issue persists. The weird part is I am getting the exact same slow download speeds in all the distros which is 1.1Mbps (It should have been 45Mbps up+down) [checked through fast.com], but Im getting the full upload speed. [Using a fiber connection]
Things I have tried -
  • Turning off the power management from this post
  • Turning off IPV6 for that particular interface
  • Updated grub and my system
Here is the output for
ip a
wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000 inet 192.168.1.47/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp0s20f3 valid_lft 86044sec preferred_lft 86044sec valid_lft forever preferred_lft forever
Here is some information about my Network Controller
Network controller: Intel Corporation Device 43f0 (rev 11)
    Subsystem: Bigfoot Networks, Inc. Device 1652
    Flags: bus master, fast devsel, latency 0, IRQ 16
    Memory at 6205274000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: <access denied>
    Kernel driver in use: iwlwifi
    Kernel modules: iwlwifi
Also
10.817111] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX203, REV=0x354
To add further, I dual boot Windows 10 and Ubuntu as of now. The wifi works perfectly fine on windows 10. So after trying everything else I tried to connect my phone to my wifi and then created a hotspot from my phone. I then connected my laptop[with Ubuntu] to that hotspot and it works perfectly fine. The only issue is that I cannot keep doing this forever. Please help me out regarding this and do let me know if there is any command that i specifically need to check.
Thanks a lot for your time.
newka
  • 39
Alright its totally my fault. The firewall on the router was set to strict and I changed it to be "low" and I'm getting the full bandwidth. Anyways thank you for your time, guys
newka
  • 39
