My uncommon laptop model: 15-au070nb is an hp pavilion notebook. My drive is formatted in the GPT partition format. I try to dualboot my pc. My problem is that after trying the installer 20+ times (I'm not even kidding) that linux would not install. I've tried every combination of bios settings (I cannot disable secure boot because my bios doesn't have it) I have tried to install in uefi mode and legacy mode, both didn't work.
I tried making the usb several times over with different software like balena etcher or rufus. With rufus I tried the GPT partition scheme with no succes. I tried the MBR with no succes either. I also tried the 'nomodeset' and the other that I don't remember the name of.
The problem with the installer is that it gets stuck at random moments of the installation the most common part where it gets stuck is with copying files.
It feels like my computer is blocking the installation somehow but windows installs without any problems
Thank you for helping.
In your 'UEFI/BIOS' you have to disable secure boot. Otherwise it won't install any Linux distribution or any other than Microsoft Operating System.
'Most x86 hardware comes from the factory pre-loaded with Microsoft keys. This means the firmware on these systems will trust binaries that are signed by Microsoft. Most modern systems will ship with SB enabled - they will not run any unsigned code by default, but it is possible to change the firmware configuration to either disable SB or to enrol extra signing keys.'
and
'SB is also not meant to lock users out of controlling their own systems. Users can enrol extra keys into the system, allowing them to sign programs for their own systems. Many SB-enabled systems also allow users to remove the platform-provided keys altogether, forcing the firmware to only trust user-signed binaries.'
quotes from enter link description here.
So if you cannot disable 'secure boot' in your UEFI/BIOS, you have to enrol the extra keys. Take a look at enter link description here for example.
Or you can try putting your harddisk in another system, install it there, and put the harddisk in your own system again. Although I am not sure if that will work ( missing extra keys in UEFI ).
Will it allow you to install Ubuntu to an external drive? Or does that fail too? If that fails is surely is UEFI that stops the installation proces.
And check the health of your hardware as well.
Hoping to have pointed you in the right direction.
Edit 211113 Are you sure your USB stick is ok? If you have another one, try it with that.
Joepie Es
  • 1,570
