Begining of the boot the screen remain stuck on black screen. How will I solve this problem?
Asked
Active
Viewed 103 times
- If you are using a VM then I highly recommend you to use ram more than 1GB i.e, you can use 1.5GB atleast because as it is a VM you have allocate more RAM than normally minimum required amount.
- If you are using ubuntu as a dualboot or as a primary os then, are you able to see grub?
Akshith
- 103
- 5
