I downloaded the latest release of the nibbler chess GUI and i cannot find out what to do with the unzipped files. Can anyone help me? There is no word of explanation on GitHub. Do i need to install the unzipped files or just open it in some way? Thank you very much for your help and your time.
The simplest method is to set nibbler file to be executable and then run it by ./nibbler.
If you want to install it to the system with desktop icon - use below commands
cd ~/Downloads
wget -c https://github.com/rooklift/nibbler/releases/download/v2.2.1/nibbler-2.2.1-linux.zip
sudo unzip nibbler-2.2.1-linux.zip -d /opt/
sudo chmod +x /opt/nibbler-2.2.1-linux/nibbler
sudo mkdir -p /usr/local/share/applications
cat <<EOF | sudo tee /usr/local/share/applications/nibbler.desktop
[Desktop Entry]
Type=Application
Version=1.0
Name=Nibbler
Icon=/opt/nibbler-2.2.1-linux/resources/app/pieces/K.png
Exec=/opt/nibbler-2.2.1-linux/nibbler
Terminal=false
StartupNotify=false
Categories=Game;BoardGame;
EOF
As the result you will find Nibbler in the desktop environment menu.
To call Nibbler from terminal you have to execute below command to create a symlink for it:
sudo ln -s /opt/nibbler-2.2.1-linux/nibbler /usr/local/bin/nibbler
and then call it using nibbler command.
You are free to report issue to Nibbler developer about possible installer, snap/flatpak/appimage/whatever package, icon and so on.
- 103,263
