I wanted to install wine in Ubuntu 20.04, but I did all the way like in official instruction here...
sudo dpkg --add-architecture i386
wget -nc https://dl.winehq.org/wine-builds/winehq.key
sudo apt-key add winehq.key
sudo add-apt-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ focal main'
sudo apt install --install-recommends winehq-stable
but then this error message appears in the terminal:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: winehq-stable : Depends: wine-stable (= 6.0.1~hirsute-1) E: Unable to correct problems, you have held broken packages.
karel
  • 122,292
  • 133
  • 301
  • 332
I found the answer here.
The answer to my question is:
Nmath
  • 12,664
