I'm a complete newcomer to Linux, and I want to install a couple of distributions in VirtualBox so I can see what they're like. I've installed the program and followed various tutorials online but every time I try to create a machine I get the following error:
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please try setting it up again by executing
'/sbin/vboxconfig'
as root.
If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
I've tried entering "sudo /sbin/vboxconfig" into the terminal but that hasn't helped. This is a brand new installation of Ubuntu; I haven't messed around with anything. Any help would be appreciated, as well as recommendations for an orderly way to learn Linux instead of just mucking around on YouTube.
