since yesterday I'm facing the problem that I can't use W-LAN or Bluetooth with my Laptop device. I was running several commands from other threads (see below), but none was helping. At the end I booted the system with a different Kernel I had installed and finally the W-LAN worked again.
Today, the yesterday's issue appeared again but this time I'm unable to figure out how to get along. Any help is appreciated.
Here, the error output looks similar to the one I've got, but execution of the commands rmmod and modprobe did not help. This did not help either.
System OS: Ubuntu 20.04.3 LTS with Kernel 5.4.0-89-generic x86_64
My device's network controller: Intel Corporation Wireless-AC 9462
lspci -kvnn | sed -n '/Network/,/^$/ p' gives some more details:
00:14.3 Network controller [0280]: Intel Corporation Wireless-AC 9462 [8086:02f0]
    DeviceName: Onboard - Ethernet
    Subsystem: Intel Corporation Wireless-AC 9462 [8086:02a4]
    Flags: bus master, fast devsel, latency 0, IRQ 16
    Memory at c431c000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: <access denied>
    Kernel driver in use: iwlwifi
    Kernel modules: iwlwifi
dmesg | grep iwlwifi outputs:
[    5.998179] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    6.012643] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 58.3.35.22
[    6.012888] iwlwifi 0000:00:14.3: loaded firmware version 50.3e391d3e.0 op_mode iwlmvm
[    6.068201] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9462, REV=0x354
[    7.093785] iwlwifi 0000:00:14.3: Collecting data: trigger 15 fired.
[    7.093880] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    7.093881] iwlwifi 0000:00:14.3: Status: 0x00000000, count: -330306978
[    7.093882] iwlwifi 0000:00:14.3: Loaded firmware version: 50.3e391d3e.0
[    7.093883] iwlwifi 0000:00:14.3: 0xB7E103D4 | ADVANCED_SYSASSERT
[    7.093883] iwlwifi 0000:00:14.3: 0x988EB45E | trm_hw_status0
... some more lines of error output
[ 7.094159] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM [ 7.094253] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR [ 7.094451] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0xa5a5a5a2, CPU2 Status: 0xa5a5a5a2 [ 7.094452] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110 [ 7.094453] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error [ 7.105807] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
Update
Following Pilot6 advice to install HWE it still does not work. However the error message is more precise this time:
Direct firmware load for iwlwifi-QuZ-a0-jf-b0-64.ucode failed with error -2
uname -r outputs 5.14.14-051414-generic.
[    5.604933] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    5.608449] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-jf-b0-64.ucode failed with error -2
[    5.610141] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    5.610156] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[    5.610428] iwlwifi 0000:00:14.3: loaded firmware version 63.c04f3485.0 QuZ-a0-jf-b0-63.ucode op_mode iwlmvm
[    5.692788] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9462, REV=0x354
[    6.722141] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[    6.722170] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[    6.722217] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[    6.722221] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    6.722700] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    6.722702] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -71178302
[    6.722705] iwlwifi 0000:00:14.3: Loaded firmware version: 63.c04f3485.0 QuZ-a0-jf-b0-63.ucode
[    6.722707] iwlwifi 0000:00:14.3: 0x89C6A936 | ADVANCED_SYSASSERT
[    6.722710] iwlwifi 0000:00:14.3: 0x8E507E67 | trm_hw_status0
... some more code
[ 6.723211] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID [ 6.723216] iwlwifi 0000:00:14.3: 0x00000201 | FSEQ_CNVR_ID [ 6.723251] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP [ 6.723295] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP [ 6.723378] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM [ 6.723446] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR [ 6.723467] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110 [ 6.723470] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms). [ 7.921900] drm_kms_helper snd_timer cec iwlwifi efi_pstore intel_wmi_thunderbolt snd processor_thermal_device_pci_legacy processor_thermal_device rc_core processor_thermal_rfim processor_thermal_mbox i2c_algo_bit processor_thermal_rapl ucsi_acpi(+) mxm_wmi 8250_dw ee1004 fb_sys_fops wmi_bmof intel_rapl_common typec_ucsi mei_me syscopyarea sysfillrect soundcore hid_multitouch cfg80211 sysimgblt mei intel_pch_thermal intel_soc_dts_iosf typec int3403_thermal int340x_thermal_zone mac_hid int3400_thermal acpi_pad acpi_thermal_rel acpi_tad sch_fq_codel overlay iptable_filter ip6table_filter ip6_tables br_netfilter bridge stp llc arp_tables msr parport_pc ppdev lp drm parport ip_tables x_tables autofs4 rtsx_usb_sdmmc rtsx_usb uas usb_storage hid_generic crc32_pclmul i2c_hid_acpi nvme xhci_pci i2c_i801 xhci_pci_renesas intel_lpss_pci nvme_core i2c_smbus sdhci_pci ahci cqhci intel_lpss i2c_hid sdhci libahci idma64 hid wmi video pinctrl_cannonlake [ 8.386160] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
Update 2
@heynnema
dkms status outputs:
virtualbox, 6.1.26, 5.11.0-38-generic, x86_64: installed
virtualbox, 6.1.26, 5.14.14-051414-generic, x86_64: installed
virtualbox, 6.1.26, 5.3.0-45-generic, x86_64: installed
virtualbox, 6.1.26, 5.4.0-89-generic, x86_64: installed
sudo dmesg | grep iwlwifi outputs the same output as before.
Update 3
Following @unbi-rabka answer did not solve the problem.I still do not have wireless connection.
sudo dmesg | grep iwlwifi outputs:
[    3.373741] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.381121] iwlwifi: No config found for PCI dev 02f0/0000, rev=0x354, rfid=0x0
[    3.381223] iwlwifi: probe of 0000:00:14.3 failed with error -22
Also I tried to install a brand-new installation of Ubuntu-18.04 alongside my current installation. But it did not help either.
I just had the problem recently (August 2022) after years of no problems with an Intel 3160 wlp2s0. One of the incremental upgrades to 20.04 I suspect. I solved it by upgrading to 22.04
i use kubuntu 20.04 and Wifi 6E AX210
i have same issue after update os, so i try this on my pc and its works
mv /lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm /lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm.bak
after rename, you must restart your pc
unbi rabka
For anyone else arriving here looking for a solution, I've had a similar issue with a laptop on 20.04, with an Intel 9461 adapter.
It appears to me to be a kernel/driver/firmware mismatch. I was able to resolve by upgrading the linux-firmware package. To do this, I looked at this page to see the available versions of this package for 20.04 and newer releases.
I downloaded the newest, but that did not change the problem, so next I tried the next-newer than what is available on 20.04, which is from 21.04 (hirsuite) and is version 1.197. This fully resolved the problem, and should not be broken by an update, assuming any linux-firmware updates to 20.04 maintain their version scheme. Any updates to this package in the focal repository would be versioned 1.187.x > 1.187.29, which would be greater than the current version, but always lower than 1.197...
Here is a link to the mirrors page for a direct download to version 1.197 of the linux-firmware package.
EDIT: Scratch that! Looks like wpa-supplicant.service was restarted during the apt installation of 1.197, and it just happened to do so when a working firmware file was the only one present in /lib/firmware/. Subsequently, downgrading to version 1.187 is giving a working combination.
I've pinned that package to the 1.187 version and now it is actually working, even after a reboot.
This is what I did on 20.04:
user@computer:~$ cat /etc/apt/preferences.d/linux-firmware-iwlwifi-on-5-13-0-fix
Package: linux-firmware
Pin: release a=focal-updates
Pin-Priority: -10
Package: linux-firmware Pin: release a=focal Pin-Priority: 1001
