I want to upgrade my Ubuntu 16.04 server to Ubuntu 18.04 and I'm running the following commands to do so;
apt update -y
apt upgrade -y
do-release-upgrade
apt update command runs fine with the following output;
# apt update -y
Hit:1 https://esm.ubuntu.com/infra/ubuntu bionic-infra-security InRelease
Hit:2 https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates InRelease
Reading package lists... Done
Building dependency tree
5 packages can be upgraded. Run 'apt list --upgradable' to see them.
However when running the apt upgrade command, it returns the following errors;
# apt upgrade -y
Calculating upgrade... Done
*The following packages could receive security updates with UA Infra: ESM service enabled:
  libkrb5-3 libgssapi-krb5-2 libk5crypto3 libkrb5support0 libzstd1
Learn more about UA Infra: ESM service for Ubuntu 16.04 at https://ubuntu.com/16-04
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
The following packages have been kept back:
The following packages will be upgraded:
  libzstd1
1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
1 esm-infra security update
Need to get 189 kB of archives.
After this operation, 132 kB of additional disk space will be used.
Err:1 https://esm.ubuntu.com/infra/ubuntu bionic-infra-security/main amd64 libzstd1 amd64 1.3.3+dfsg-2ubuntu1+esm1
  401  Unauthorized
E: Failed to fetch https://esm.ubuntu.com/infra/ubuntu/pool/main/libz/libzstd/libzstd1_1.3.3+dfsg-2ubuntu1+esm1_amd64.deb  401  Unauthorized
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I'm not sure what to do at this point. How can I solve this?
