I tried
alias sct='systemctl'
complete -F _systemctl sct
But the function _systemctl is not found until I run the original command systemctl in the session. This function loads dynamically or somehow and contains many other same functions inside.
OS - Ubuntu 20.04
tehkonst
  • 363
Create a file named /etc/bash_completion.d/systemctl:
if [[ -r /usr/share/bash-completion/completions/systemctl ]]; then
    . /usr/share/bash-completion/completions/systemctl && complete -F _systemctl systemctl sct
fi
You can restart bash-completion by sourcing . /etc/bash_completion
I found a file with autocomplete functions for systemctl in my system and added a line to load it:
source /usr/share/bash-completion/completions/systemctl
tehkonst
  • 363
Just
_completion_loader systemctl
But I recommend use bash function instead of bash alias so you can define some shortcuts for sub commands, here is an example:
sct ()
    case $1 in
        e)
            shift;
            sudo systemctl enable --now "$@"
        d)
            shift;
            sudo systemctl disable --now "$@"
        s)
            shift;
            systemctl status "$@"
        S)
            shift;
            sudo systemctl stop "$@"
        r)
            shift;
            sudo systemctl restart "$@"
            systemctl "$@"
    esac
In addition, in order to make bash completion work for these shortcuts, you need to add them to array VERBS in corresponding keys in /usr/share/bash-completion/completions/systemctl. Here is an example for sct e :
    local -A VERBS=(
-       [DISABLED_UNITS]='enable'
+       [DISABLED_UNITS]='enable e'
But these modifications in /usr/share/bash-completion/completions/systemctl may lost over an update. I haven't found a perfect way to override it yet, maybe later.
alzee
  • 121
