I am trying to get Ubuntu running using WSL2 on my office laptop.
Problem:
When I try to run apt-get update or any install command, eg: apt-get install gcc, it always ends up with 101: Network is unreachable.
Solutions I have tried so far:
Firewall
My initial guess was that my office firewall may be blocking the connection, but on quick ping check I see that it works fine. Also I have browsed the URLs in chrome and it works without any issues.
$ ping 91.189.91.39 PING 91.189.91.39 (91.189.91.39) 56(84) bytes of data. 64 bytes from 91.189.91.39: icmp_seq=1 ttl=51 time=256 ms 64 bytes from 91.189.91.39: icmp_seq=2 ttl=51 time=256 ms ^C --- 91.189.91.39 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1002ms rtt min/avg/max/mdev = 255.540/255.757/255.975/0.217 msresolver configuration file issue.
I have tried changing the default nameserver to 8.8.8.8 and other DNS providers as well but didn't resolve the issue. Also since ping works, DNS resolver shouldn't be a problem.
Now there are few more solution which I am able to find, like forcing apt to use IPv4, deleting hypervisor switching adapter and other such solutions but their problem doesn't seem to corelate with what I am facing and I don't want to keep shooting arrows in dark.
Any help or direction pointing will be very much appreciated. Thank you
Error log:
$ sudo apt-get update
Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
Err:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
Err:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Err:5 http://archive.canonical.com/ubuntu focal InRelease
Cannot initiate the connection to archive.canonical.com:80 (2001:67c:1360:8c01::16). - connect (101: Network is unreachable) Cannot initiate the connection to archive.canonical.com:80 (2001:67c:1360:8c01::1b). - connect (101: Network is unreachable) Cannot initiate the connection to archive.canonical.com:80 (2001:67c:1562::1c). - connect (101: Network is unreachable) Could not connect to archive.canonical.com:80 (91.189.92.191), connection timed out Could not connect to archive.canonical.com:80 (91.189.92.150), connection timed out Could not connect to archive.canonical.com:80 (91.189.91.15), connection timed out
Reading package lists... Done
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable)
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable)
W: Failed to fetch http://archive.canonical.com/ubuntu/dists/focal/InRelease Cannot initiate the connection to archive.canonical.com:80 (2001:67c:1360:8c01::16). - connect (101: Network is unreachable) Cannot initiate the connection to archive.canonical.com:80 (2001:67c:1360:8c01::1b). - connect (101: Network is unreachable) Cannot initiate the connection to archive.canonical.com:80 (2001:67c:1562::1c). - connect (101: Network is unreachable) Could not connect to archive.canonical.com:80 (91.189.92.191), connection timed out Could not connect to archive.canonical.com:80 (91.189.92.150), connection timed out Could not connect to archive.canonical.com:80 (91.189.91.15), connection timed out
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
Error log by forced IPv4 usage :
sudo apt-get update -o Acquire::ForceIPv4=true
Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out
Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out
Unable to connect to archive.ubuntu.com:http:
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Unable to connect to archive.ubuntu.com:http:
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Unable to connect to archive.ubuntu.com:http:
W: Failed to fetch http://archive.canonical.com/ubuntu/dists/focal/InRelease Could not connect to archive.canonical.com:80 (91.189.92.191), connection timed out Could not connect to archive.canonical.com:80 (91.189.92.150), connection timed out Could not connect to archive.canonical.com:80 (91.189.91.15), connection timed out
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out
