I'm trying to make the terminal always display the execution time of a process that I call via the command line (i.e., I want to find out how long it takes to for the process to finish).
I know that if you type time before the command, at the end it will display the execution time, but the idea is not to type anything but the command and receive the execution time at the end if possible.
Luis
Use tcsh and set time
A very easy method to time each command is to install and use the shell tcsh (instead of bash which is standard in Ubuntu) and set the variable time,
tester@my-laptop:~$ sudo apt install tcsh
tester@my-laptop:~$ tcsh my-laptop:~> set time my-laptop:~> sleep 3 0.003u 0.000s 0:03.00 0.0% 0+0k 0+0io 0pf+0w my-laptop:~>
Show the wall-time when each prompt was printed in bash
Maybe it would be enough for you to have a clock in the prompt, so that you see the 'wall-time' when the command finished and the terminal window returned to prompt?
A crude prompt to enter interactively for this purpose would be
PS1='$(date '+%T') $ '
or to add to the current prompt
PS1='$(date '+%T') '"$PS1"
Reset to the standard prompt with
source ~/.bashrc
sudodus
  • 47,684
-2
run the command with time(which is a shell keyword aka a command) like this. time foobar or time sleep 1. anorthor example is
#!/bin/bash
#how big is your file system
time tree /
lnee
  • 878
