I am using a new HP laptop and was trying to install Ubuntu via live USB. As I proceed to install Ubuntu 20.04 the installation window only shows the the USB memory. The live USB has failed to detect the internal hard drive. I have a hard drive of 1 TB. I have also disable secure boot too. I am using windows 11. What should I do to fix this and install Ubuntu 20.04?
Sreej
The most likely reason is that ‘fast start up’ hasn’t been disabled in Windows, meaning the drive won’t be considered in a safe state for the Ubuntu installer to write to it. Disable that (from within Windows) and retry; if it doesn’t work, I would suggest shrinking your windows partition from within Windows (creating some unallocated space for the Ubuntu installer).
I’ve not used Windows 11, but in 10 you disable fast start up like this:
Click on start / settings / system / Power and sleep settings / Additional power settings / Choose what the power buttons do / Change settings that are currently unavailable / uncheck the box allowing fast start-up. (If anyone using windows 11 knows exactly how to do it, please feel free to edit my answer with more accurate instructions!)
You could also try booting a live usb session (‘try Ubuntu’), then see if your drive is found using disks or gparted. You can also shrink the Windows partition using gparted but it may be safer using the Windows tool.
Do obviously back up your Windows data before doing anything like resizing the partition.
Will
  • 2,483
  • 20
  • 34
You may try mount the hard drive and then try-
  1. Boot into the live USB and this time, select Try Ubuntu without installing
  2. Wait for sometime to boot into desktop, open Disks and mount the hard drive
  3. Continue with the installation (shortcut in desktop) and the hard drive should come up
I have an experience like this; I had an hard drive and I wanted to install Ubuntu on it, but instead it shows my main hard drive
