For the past while, I've been trying to run sudo apt update so I can prep my computer to upgrade to Ubuntu 21.10. However, every time I run it, I get a combination of these types of errors:
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ppa.launchpad.net/ubuntuhandbook1/audacity/ubuntu focal InRelease: Couldn't execute /usr/bin/apt-key to check /var/lib/apt/lists/partial/ppa.launchpad.net_ubuntuhandbook1_audacity_ubuntu_dists_focal_InRelease
E: The repository 'http://ppa.launchpad.net/webupd8team/java/ubuntu focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
E: The repository 'http://ppa.launchpad.net/linuxmint-tr/araclar/ubuntu focal InRelease' is no longer signed.
E: Failed to fetch http://ppa.launchpad.net/linuxmint-tr/araclar/ubuntu/dists/focal/InRelease  403  Forbidden [IP: 91.189.95.85 80]
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://us.archive.ubuntu.com/ubuntu focal-updates InRelease: Couldn't execute /usr/bin/apt-key to check /var/lib/apt/lists/partial/us.archive.ubuntu.com_ubuntu_dists_focal-updates_InRelease
E: Failed to fetch https://dl.bintray.com/scratux/stable/dists/focal/InRelease  403  Forbidden [IP: 34.214.192.151 443]
There are tons of these types of errors every time I run it. What's going on, and how can I fix it?
Here's the full output of my command: https://docs.google.com/document/d/1PziOBmZn1L1A0AuH5rc7jSiCDQLBSdmdv62VIagRh60/edit?usp=sharing
Note: sudo add-apt-repository --remove ppa:(ppa that needs to be removed) only works for some of these errors, and even then it doesn't always work.
