I want to add /opt/jdk-16.0.2 to update-java-alternatives, but there is no .jinfo file. File should be there, because I have openjdk 16.0.2
I had no problems with adding java to update-alternatives java command, but I don't want to do it with every java-related binary.
I installed openjdk by extracting it from archive and changing JAVA_HOME to /opt/jdk-16.0.2 Should I do something more? Can I generate .jinfo file?
I'd like to use update-java-alternatives to switch between Java versions. I don't want to play with scripts and update-alternatives java
https://askubuntu.com/a/388693
update-java-alternatives requires presence of a file with extension .jinfo in directory /usr/lib/jvm. The opendjk package is shipped with a .jinfo file, the jdk of Oracle (formerly Sun) is not. As alternative, you configure alternatives without update-java-alternatives:
