I have a number of JPEG-2000 .jp2 and .j2k images that I want to preview on Nautilus or Nemo. How can I tell the file managers to create thumbnails for those files?
- 1,456
Some methods for previewing JPEG-2000 images that work on Nautilus, Nemo, and Caja.
Method 1: Use opj_decompress
Install
libopenjp2-toolssudo apt install libopenjp2-toolsThis package comes with the tools and codecs needed to convert JP2 and J2K images to PNG thumbnails, namely
opj_decompress,opj_dump, andlibopenjp2-7.Notes:
libopenjp2-toolsis not available on Ubuntu 14.10 and earlier.- If you are on Ubuntu 18.04 or later, you may have to install
libgdk-pixbuf2.0-bin(which is usually pre-installed):
This package providessudo apt install libgdk-pixbuf2.0-bingdk-pixbuf-thumbnailerwhich will be used to resize the PNGs generated byopj_decompressto a more suitable size for thumbnails.
Get the mime-types of JP2 and J2K images
- Right-click a JP2 or J2K image, select Properties.
- On the Basic tab, take note of what is in the parentheses for the Type field. In my case (Ubuntu 20.04), it's
image/jp2for JP2 images andimage/x-jp2-codestreamfor J2K and J2C images.
Alternatively, you can use
xdg-mimeto get these mime-types. For example, if you haveexample.jp2andexample.j2kin~/Pictures, issue these commands:xdg-mime query filetype ~/Pictures/example.jp2 xdg-mime query filetype ~/Pictures/example.j2kCreate a thumbnailer script for JP2 and J2K images
- Create a file named
jp2-thumbnailer-binin/usr/local/bin:sudo nano /usr/local/bin/jp2-thumbnailer-bin - Copy the following script (based on the method from this) into the file (use Ctrl+C to copy and Ctrl+Shift+V to paste into
nanowindow):#!/bin/bashsInFile="$1" nThumbSize="$2" sOutFile="$3"
Get the dimensions of the input image
sInfo="$(opj_dump -i "$sInFile")" sSize="$(echo "$sInfo" | grep x1 | sed -r 's|.x1=(.), y1=(.*)|\1\t\2|')" nWidth="$(echo "$sSize" | cut --fields=1)" nHeight="$(echo "$sSize" | cut --fields=2)"
Get the large dimension of the input image
if((nWidth>nHeight)); then nLargeSize="$nWidth" else nLargeSize="$nHeight" fi
Generate output thumbnail;
Images larger than the default thumbnail size (256x256 or
128x128 pixels) are scaled down so their large dimension
is at most 256 or 128 pixels. This significantly reduces
thumbnail generation time.
if((nLargeSize<=nThumbSize)); then /usr/bin/opj_decompress -i "$sInFile" -o "$sOutFile".png else nResolutions="$(echo "$sInfo" | grep numresolutions | cut --delimiter='=' --fields=2 | sort --general-numeric-sort | sed 1q)" nReduce="$(echo "f=l($nLargeSize/$nThumbSize)/l(2);scale=0;f/1" | bc -l)" if((nReduce<nResolutions)); then nReduceFactor="$nReduce" else nReduceFactor="$((nResolutions-1))" fi /usr/bin/opj_decompress -i "$sInFile" -r "$nReduceFactor" -o "$sOutFile".png fi if [[ -e /usr/bin/gdk-pixbuf-thumbnailer ]]; then /usr/bin/gdk-pixbuf-thumbnailer -s "$nThumbSize" "$sOutFile".png "$sOutFile" rm "$sOutFile".png else mv "$sOutFile".png "$sOutFile" fi
- Press Ctrl+O and Enter to save the file, and Ctrl+X to exit
nanoand return to the terminal. - Next, make the file executable with:
sudo chmod +x /usr/local/bin/jp2-thumbnailer-bin
Note: If you use Nemo or Caja, you can actually put the script somewhere in your home directory (e.g.
~/.local/bin) and run commands like the above withoutsudo. If you use Nautilus, however, you can only do so iflibgnome-desktopbeing used by Nautilus is older than 3.28.2. To get the version number oflibgnome-desktop, issue this command:apt list --installed | grep libgnome-desktop | cut -d ' ' -f 2 | cut -d '-' -f 1- Create a file named
Create a thumbnailer entry for JP2 and J2K images
- First, create a folder named
thumbnailersin~/.local/share.mkdir -p ~/.local/share/thumbnailers - Create a file named
jp2.thumbnailerin that folder.nano ~/.local/share/thumbnailers/jp2.thumbnailer - Copy these lines into the file (use Ctrl+C to copy, Ctrl+Shift+V to paste into
nanowindow):[Thumbnailer Entry] Exec=/usr/local/bin/jp2-thumbnailer-bin %i %s %o MimeType=image/jp2;image/x-jp2-codestream; - Press Ctrl+O and Enter to save the file, and Ctrl+X to exit
nano.
Notes:
- Put the mime-types found earlier in the third line listed above (the
MimeTypekey); separate each mime-type with a semicolon (;) and optionally end the line with a semicolon. - If you want thumbnails for JP2 and J2K images to be available to all users, place this thumbnailer entry in
/usr/share/thumbnailersinstead of~/.local/share/thumbnailers:sudo nano /usr/share/thumbnailers/jp2.thumbnailer - A GUI text editor like
geditorxedcan also be used to create and edit the thumbnailer entry. However, if you plan to place it in/usr/share/thumbnailers, usingnanois highly recommended.
Enable thumbnailing for JP2 images
The file manager may disable thumbnailing for JP2 images. To check whether this is the case, issue one of these commands, for Nautilus, Nemo, and Caja respectively:
gsettings get org.gnome.desktop.thumbnailers disable gsettings get org.cinnamon.desktop.thumbnailers disable gsettings get org.mate.thumbnailers disableIf the result is
[]or[''], then the file manager does not disable thumbnailing for any file types (and you can go straight to step 6). However, if the result is['image/jp2'], then thumbnailing for JP2 images is disabled. To re-enable it, issue one of these commands (for Nautilus, Nemo, and Caja respectively):gsettings set org.gnome.desktop.thumbnailers disable "[]" gsettings set org.cinnamon.desktop.thumbnailers disable "[]" gsettings set org.mate.thumbnailers disable "[]"Alternatively, you can use dconf Editor:
- First, install
dconf-editor:sudo apt install dconf-editor - Open dconf Editor, then go to one of these places (for Nautilus, Nemo, and Caja respectively):
- org → gnome → desktop → thumbnailers → disable.
- org → cinnamon → desktop → thumbnailers → disable.
- org → mate → desktop → thumbnailers → disable.
- Turn off Use default value.
- Change the value in the Custom value box from
['image/jp2']to either[]or['']. - Click Apply in the bottom-right corner and close dconf Editor.
- First, install
Clear old cached thumbnails and restart the file manager
- First, fully close the file manager with one of these commands:
nautilus -q nemo -q caja -q - Next, delete cached failed thumbnails:
rm -r ~/.cache/thumbnails/fail - Optionally, delete all cached thumbnails (if you previously used unoptimized thumbnailer entries or scripts that created large thumbnails):
rm -r ~/.cache/thumbnails/* - Finally, reopen the file manager. JP2 and J2K images should have their thumbnails now.
Method 2: Use convert
convert can be used to create thumbnails for JP2 and J2K images on Ubuntu 14.04 or Ubuntu 20.10 and later.
Install
imagemagickwhich provides theconverttoolsudo apt install imagemagickGet the mime-types of JP2 and J2K images (see Use opj_decompress, step 2)
Create a thumbnailer entry for JP2 and J2K images (see Use opj_decompress, step 4 for details)
The contents of
~/.local/share/thumbnailers/jp2.thumbnailerwithconvertas the thumbnailer program:[Thumbnailer Entry] Exec=/usr/bin/convert %i -thumbnail %sx%s png:%o MimeType=image/jp2;image/x-jp2-codestream;Enable thumbnailing for JP2 images (see Use opj_decompress, step 5)
Clear old cached thumbnails and restart the file manager (see Use opj_decompress, step 6)
Method 3: Use gm
gm supports JPEG-2000 images on Ubuntu 14.04 and 16.04.
Install
graphicsmagickwhich provides thegmtoolsudo apt install graphicsmagickGet the mime-types of JP2 and J2K images (see Use opj_decompress, step 2)
The contents of
~/.local/share/thumbnailers/jp2.thumbnailerwithgmas the thumbnailer program:[Thumbnailer Entry] Exec=/usr/bin/gm convert %i -thumbnail %sx%s png:%o MimeType=image/jp2;image/x-jp2-codestream;Enable thumbnailing for JP2 images (see Use opj_decompress, step 5)
Method 4: use totem-video-thumbnailer
totem-video-thumbnailer can thumbnail JP2 and J2K images on Ubuntu 18.04 and later.
Install
totemandgstreamer1.0-plugins-badsudo apt install totem gstreamer1.0-plugins-badtotemprovidestotem-video-thumbnailer, whilegstreamer1.0-plugins-badcomes with the codecs needed bytotem-video-thumbnailerto handle JP2 and J2K images.Note:
totemis the default video player on GNOME desktops so it is pre-installed on Ubuntu.gstreamer1.0-plugins-badis not pre-installed, however, probably because it's only a suggested package fortotem.Get the mime-types of JP2 and J2K images (see Use opj_decompress, step 2)
The contents of
~/.local/share/thumbnailers/jp2.thumbnailerwithtotem-video-thumbnaileras the thumbnailer program:[Thumbnailer Entry] Exec=/usr/bin/totem-video-thumbnailer -s %s %u %o MimeType=image/jp2;image/x-jp2-codestream;Enable thumbnailing for JP2 images (see Use opj_decompress, step 5)
Method 5: Use ffmpeg
ffmpeg supports JP2 and J2K images on Ubuntu 16.04 and later.
Install
ffmpegsudo apt install ffmpegGet the mime-types of JP2 and J2K images (see Use opj_decompress, step 2)
The contents of
~/.local/share/thumbnailers/jp2.thumbnailerwithffmpegas the thumbnailer program:[Thumbnailer Entry] Exec=/usr/bin/ffmpeg -y -i %i -filter scale=%s:%s:force_original_aspect_ratio=1 -f apng %o MimeType=image/jp2;image/x-jp2-codestream;Enable thumbnailing for JP2 images (see Use opj_decompress, step 5)
Summary
| Tested on → | Ubuntu 14.04 | Ubuntu 16.04 | Ubuntu 18.04, 20.04; Linux Mint 20 Cinnamon; Ubuntu MATE 20.04 | Ubuntu 20.10, 21.04 |
| opj_decompress | N/A | ✔️ | ✔️ | ✔️ |
| convert | ✔️ | ❌️ | ❌️ | ✔️ |
| gm | ✔️ | ✔️ | ❌️ | ❌️ |
| totem-video-thumbnailer | ❌️ | ❌️ | ✔️ | ✔️ |
| ffmpeg | N/A | ✔️ | ✔️ | ✔️ |
Note: Using opj_decompress or totem-video-thumbnailer is recommended as they offer significantly faster decompression speed and produce smaller thumbnails.
- 1,456
