-2
I am installing Ubuntu desktop downloaded just now from here. Only after a few minutes, "ubuntu login:" showed on the screen after pressed Ctrl+Alt+F2. I tried to input admin, then on "Password:", I can't pass it. Could you let me know what account and password I can use here?
Much thank in advance!
George
George
You seem to be confused by two things.
  1. Pressing CTRL+ALT+F2 will indeed sweep you away from your graphical desktop environment to a different input console (TTY).
    Simply press CTRL+ALT+F1 to return to the graphical desktop environment. Be patient. It might take a minute to re-load. Let it.
  2. On the F2 TTY, your password is ignored when you try to type it.
    In fact, the password IS detected by the system. The lack of any echo or feedback on the screen is a decades-old security technique.
    Use exactly the same login name and password that you use on the graphical desktop. There is no "admin" account or special password. YOUR account is the admin account; that's why you have sudo.
    If you simply enter the correct password blindly, and press Enter, the system will indeed let you in. However, it will let you in to a shell prompt, not the graphical environment.
user535733
  • 68,493
