I am trying to (re)install R in my ubuntu WSL. I already had done with
sudo apt install r-base-core But, then, later I tried to change to R 4.0 with some compressed version. Eventually, the old R 3 version was uninstalled from my system and the R 4 was running.
Basically, I wanna work with DESeq2 and install some libraries like apeglm.
As I was having some issues I deleted/removed all the folders with R, including the ones in 'local/bin' and 'local/lib'.
Now, I'm trying again from scratch but I have the following: [in]
[out]
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: r-base-core : Depends: zip but it is not installable Depends: unzip but it is not installable Depends: libpcre2-8-0 (>= 10.31) but it is not installable Recommends: r-recommended but it is not going to be installed Recommends: r-base-dev but it is not going to be installed Recommends: r-doc-html but it is not going to be installed E: Unable to correct problems, you have held broken packages.
If I try to install the depends, e.g., 'zip', I get the following:
[in]
sudo apt-get install zip
[out]
Package zip is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'zip' has no installation candidate
edit: I've been through this: https://cran.r-project.org/bin/linux/ubuntu/#install-r but it didn't work from this part on:
apt install --no-install-recommends r-base The output is like the one before, saying I missing some depends...
edit 2: I posted this question originally at StackOverflow but an advanced user told me it would be a better idea to post it actually at askubuntu, so, here I am.
I know that I have done several things wrong, but I really would appreciate it if someone could help me find some path here. I can provide more information/log if that's the case. Thanks in advance!
