I have iGpu (i7-6700) and three NVidia mining cards, all P102-100. These cards do not have display out. I am using them under Boinc for to process WCG-covid and Einstein GPU work units. They are similar to GTX 1080TI except for the video out.
If I run "nvidia-xconfig -a --cool-bits=4" I suspect the cool bits are set. Unfortunately, nvidia-config rewrites (creats) xorg.conf and after a rebooting I have lost my display. I can ssh in with putty but can no longer use VNC or the actual monitor/keyboard. The xorg.conf is setup as if the graphic coprocessor have a video output which they do not. Since there is no longer any display, nvidia-settings cannot run. I would like to set the clock speed down as the boards run too hot. If I delete the xorg.conf file and reboot then the display comes back up just fine even though the xorg.conf file no longer exists.
Can I add something to that NVidia xorg.conf file to make it use the iGpu? This is Ubuntu 18.04 and NVidia driver 470. How is it that if I delete the xorg.conf the display works using the iGpu?
jstateson@h110btc:~$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06) jstateson@h110btc:~$
Joseph Stateson
  • 143
  • 14
Read this How to configure iGPU for xserver and nvidia GPU for CUDA work
thanks to "Ian&Steve C" over at einsteinathome
I had to add the following also
Section "ServerLayout"
    Identifier     "Layout0"
    Screen         "intel"
    Screen      0  "Screen0" Rightof "intel"
    Screen      1  "Screen1" RightOf "Screen0"
    Screen      2  "Screen2" RightOf "Screen1"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Joseph Stateson
  • 143
  • 14
