Upgraded from Ubuntu 11.10 to 12.04. With 11.10, I had broken fonts. I hoped to get rid of these broken fonts with 12.04 but problem has worsened. Any solution?
Asked
Active
Viewed 4,214 times
Your font cache is probably messed up. Try clearing it.
To do the same, switch to tty1 using Ctrl+Alt+F1 and run:
$ sudo pkill -9 lightdm # or whatever your desktop manager is
$ rm ~/.fontconfig/*
$ sudo rm /var/cache/fontconfig/*
You may want to reinstall font-packages fonts-* and ttf-* at this point:
$ sudo dpkg -l | awk -F" " '/ttf-/ {print $2} /fonts-/ {print $2}' | while read line; do apt-get purge -y $line && apt-get install $line -y; done
Finally, hit Ctrl+Alt+Del to reboot.
I had some problems with the code in (2), here's my edited version:
sudo su
then
(added the -y)
