The Problem
The wifi icon suddenly disappears, leaving me with no internet access. This has happened about 3 times in the last week, and doesn't seem to be triggered by anything I do. Last one (the one I'm copying the dmesg results) was caused while I was working on emacs (had a couple inactive tabs opened in firefox).
Attempted solutions
I visited this question but my case is not related to vmware and the solution in the answer didn't work for me (nmcli network on, not even when preceded by nmcli network off).
Immediately after the last case I run dmesg -HT and saw some errors associated to iwlwifi, so I went to this question and tried to load the driver, to no avail.
I also looked at this question, but my firmware seems to be up-to-date:
stat -c %y /var/lib/apt/periodic/update-success-stamp
2021-10-09 11:47:13.854452373 -0500
The only thing that has worked for me is rebooting, and it is time consuming and really troublesome.
Asking
What should I do to avoid this kind of problem?
Context
I am running ubuntu 20.04.3 LTS (from lsb_release -a) on an asus.
uname -a
Linux MachineName 5.4.0-88-generic #99-Ubuntu SMP Thu Sep 23 17:29:00 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Results of dmesg:
dmesg -HT | grep -e '] iwlwifi' > ~/Desktop/error_iwlwifi.txt
[Fri Oct 8 19:35:32 2021] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[Fri Oct 8 19:35:32 2021] iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: iwlwifi transaction failed, dumping registers
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: iwlwifi device config registers:
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000000: 24fd8086 00100000 02800078 00000000 00000004 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000020: 00000000 00000000 00000000 01108086 00000000 000000c8 00000000 00000100
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000040: 00020010 10008ec0 001b0c10 0045e811 10110000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000060: 00000000 00080812 00000005 00000000 00010001 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 000000c0: 00000000 00000000 c823d001 0d000000 00804005 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000100: 14010001 00100000 00000000 00462031 00002000 00002000 00000014 40000001
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000120: 0000000f ef100460 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000140: 14c10003 ff190dcf dc8b28ff 15410018 00000000 0001001e 00481e1f 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: iwlwifi device memory mapped registers:
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: iwlwifi device AER capability structure:
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000000: 14010001 00100000 00000000 00462031 00002000 00002000 00000014 40000001
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: 00000020: 0000000f ef100460 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: iwlwifi parent port (0000:00:1c.5) config registers:
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000000: 9d158086 00100407 060400f1 00810010 00000000 00000000 00020200 200000f0
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000020: ef10ef10 0001fff1 00000000 00000000 00000000 00000040 00000000 0012020a
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000040: 01428010 00008001 0010000f 06724c13 70110042 004cb200 01480000 00000008
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000060: 00000000 00000837 00000000 0000000e 00010003 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000080: 00019005 fee00258 00000000 00000000 0000a00d 13111043 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 000000a0: c8030001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 000000c0: 00000000 00000000 00000000 00000000 07001001 00001842 099e0008 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 000000e0: 00e30300 88568856 00100006 00000000 00000150 4c000000 08410fb3 02000004
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000100: 14010001 00000000 00010000 00060011 00000000 00002000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000140: 2001000d 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000200: 2201001e 00b0281f 40a0280f
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: iwlwifi root port (0000:00:1c.5) AER cap structure:
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000000: 14010001 00000000 00010000 00060011 00000000 00002000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:00:1c.5: 00000020: 00000000 00000000 00000000 00000000 00000000 00000000
[Fri Oct 8 20:40:12 2021] iwlwifi 0000:02:00.0: Queue 11 is active on fifo 2 and stuck for 10000 ms. SW [155, 64] HW [90, 90] FH TRB=0x05a5a5a5a
[Fri Oct 8 20:40:18 2021] iwlwifi 0000:02:00.0: regular scan timed out
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: Error sending SCAN_ABORT_UMAC: time out after 2000ms.
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: Current CMD queue read_ptr 255 write_ptr 0
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: HW error, resetting before reading
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: Status: 0x00000040, count: -1346793048
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: Loaded firmware version: 36.77d01142.0
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | ADVANCED_SYSASSERT
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status0
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x611E33A4 | branchlink2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000712 | interruptlink1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xC0552590 | interruptlink2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | data1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | data2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | data3
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000002 | beacon time
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | tsf low
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000246 | tsf hi
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000246 | time gp2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | uCode revision type
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFFF13 | uCode version major
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | uCode version minor
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xAEAE3415 | hw version
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | board version
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | hcmd
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x81007740 | isr0
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | isr1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000018 | isr2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000000 | isr3
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xC057950D | isr4
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | last cmd Id
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x81007750 | wait_event
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | l2p_control
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000028 | l2p_duration
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | l2p_mhvalid
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x810077D0 | l2p_addr_match
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | lmpm_pmg_sel
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x81007770 | timestamp
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | flow_handler
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xC057950D | ADVANCED_SYSASSERT
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | umac branchlink1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x81007750 | umac branchlink2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | umac interruptlink1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x00000028 | umac interruptlink2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | umac data1
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x810077D0 | umac data2
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | umac data3
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x81007770 | umac major
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | umac minor
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x0E0D3B00 | frame pointer
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xB5BA25B8 | stack pointer
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0x9FEC9E88 | last host cmd
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | isr status reg
[Fri Oct 8 20:40:30 2021] iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Could not load the [0] uCode section
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Failed to start INIT ucode: -5
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Failed to run INIT ucode: -5
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Failed to start RT ucode: -5
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Collecting data: trigger 16 fired.
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: HW error, resetting before reading
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Status: 0x00000010, count: 1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Loaded firmware version: 36.77d01142.0
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | ADVANCED_SYSASSERT
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xC048BA9E | trm_hw_status0
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000713 | trm_hw_status1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xC0552590 | branchlink2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | interruptlink1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000001 | interruptlink2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | data1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000002 | data2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | data3
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000246 | beacon time
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | tsf low
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000246 | tsf hi
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFFF13 | time gp2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | uCode revision type
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xAEAE3415 | uCode version major
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | uCode version minor
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000010 | hw version
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | board version
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | hcmd
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000018 | isr0
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | isr1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000246 | isr2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | isr3
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x8529FC20 | isr4
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | last cmd Id
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xC055503F | wait_event
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | l2p_control
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xA1630018 | l2p_duration
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | l2p_mhvalid
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xA1630018 | l2p_addr_match
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | lmpm_pmg_sel
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00A01C30 | timestamp
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | flow_handler
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x8529FC20 | ADVANCED_SYSASSERT
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFA9DE | umac branchlink1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xC055503F | umac branchlink2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFFFFFF | umac interruptlink1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xA1630018 | umac interruptlink2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | umac data1
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xA1630018 | umac data2
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | umac data3
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00A01C30 | umac major
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x00000000 | umac minor
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xD1F02100 | frame pointer
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x140F5FBC | stack pointer
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0x9FEC9E88 | last host cmd
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: 0xFFFF8E84 | isr status reg
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Firmware error during reconfiguration - reprobe!
[Fri Oct 8 20:40:33 2021] iwlwifi 0000:02:00.0: Firmware not running - cannot dump error
[Fri Oct 8 20:40:35 2021] iwlwifi 0000:02:00.0: iwl_trans_wait_tx_queues_empty bad state = 0
[Fri Oct 8 20:40:35 2021] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[Fri Oct 8 20:40:35 2021] iwlwifi 0000:02:00.0: HW_REV=0xFFFFFFFF, PCI issues?
[Fri Oct 8 20:40:35 2021] iwlwifi: probe of 0000:02:00.0 failed with error -5
[Fri Oct 8 20:50:37 2021] iwlwifi 0000:02:00.0: HW_REV=0xFFFFFFFF, PCI issues?
[Fri Oct 8 20:50:37 2021] iwlwifi: probe of 0000:02:00.0 failed with error -5
[Fri Oct 8 20:52:53 2021] iwlwifi 0000:02:00.0: HW_REV=0xFFFFFFFF, PCI issues?
[Fri Oct 8 20:52:53 2021] iwlwifi: probe of 0000:02:00.0 failed with error -5
