Most of the time when I'm working, I have 4 windows open (editor, browser, mail client, terminal), and I use the multiple virtual desktops feature to put one on each window. So instead of alt-tabbing, I move to a different desktop.
The issue is that when I have them arranged on the desktops correctly and then disconnect my external monitor, they're all moved to the same desktop. When I plug the external monitor back in, then some of them are moved to the external, whereas some are still on the laptop display. Either way, it makes being mobile a very jarring experience.
Is there some way to "fix" or configure this behaviour?
Amith KK
  • 13,547
nickf
  • 554
This has been confirmed as a bug in Compiz and filed here: https://bugs.launchpad.net/compiz/+bug/763148
I agree it is very tedious. If you have any extra info to add, or to mark the bug as affecting you, use the link above.
justyn
  • 78
If you can Alt+Tab to the window you want to select, you should be able to move it even if you can't see it. Try typing Super+Ctrl+← or ↑, or →. That moves the window around.
Another thing to try is to alt-tab to the window you want, then press CTRL+ALT+Shift and an arrow. It should move the windows to the desktop you are on. But I think the first solution is more likely.
Zanna
  • 72,312
Frantumn
  • 1,459
